      • Fiber Laser
      • VF-4SS
TURNING INSERTS
HAAS TESTED. HAAS PROVEN.
SEE ALL TURNING INSERTS
  2. Lathe Tooling
  3. Turning Inserts
TURNING INSERTS OVERVIEW
There are many variables that go into choosing the correct insert for your turning operations: insert shape, geometry, grade, and more. The goal is to select an insert that meets your requirements for quality and performance, while providing good chip control, and a reasonable combination of wear resistance and toughness.
Choose the insert style (shape and size) based on the features of the part and the desired depth of cut. A larger nose radius is stronger, but requires more machine power, and increases the tendency for vibration. A smaller nose radius increases the access to fine part features, but has a weaker cutting edge.
Choose the chip breaker (geometry) based on the selected machining operation: finishing, medium, or roughing. Roughing with high depths of cut and feedrates requires an insert with a stronger cutting edge.
Finishing operations with light depths of cut and lower feedrates produce lower cutting forces, so cutting-edge strength is not as important. Medium turning operations, with a wide range of depths of cut and feedrate, require a more versatile geometry.
Choose the insert grade (coatings) based on the type of material being cut, the specific machining operation (finishing, medium, roughing), and the cutting conditions (smooth, lightly interrupted, heavily interrupted). The insert grade and the chip breaker complement each other to provide specific performance characteristics. A tougher grade can compensate for a cutting edge with less strength, while a more wear resistant grade can provide longer tool life on a stronger cutting edge.
INSERT STYLES
  • Insert Styles
  • Chipbreakers
  • Insert Grades
Insert Styles
C-Style Inserts – 80° Rhombic
For external machining and facing. The large point angle is very rigid, and good for rough machining. This is the most commonly used insert.
D-Style Inserts – 55° Rhombic
The smaller point angle of this insert is more versatile for finishing and detail work, but it has less cutting-edge strength than other geometries.
V-Style Inserts – 35° Rhombic
T-Style Inserts – 60° Triangle
For internal machining. The 60° cutting angle provides medium cutting-edge strength that allows for both ID roughing and finishing applications.
W-Style Inserts – 80° Trigon
This insert has 3 cutting edges per side. The 80° cutting angle provides high cutting-edge strength for roughing, but the depth of cut is limited by the short cutting edge.
LARGE NOSE ANGLE
• Stronger cutting edge
• Higher cutting forces
• More vibration
• Higher feedrates
SMALL NOSE ANGLE
• Better access to features
• Lower cutting forces
• Weaker cutting edge
• Lower vibrations
Chipbreakers
HFF
HAL
For cost-effective machining of aluminum, non-ferrous metals, and plastics. Extremely sharp cutting edges result in optimum part finishes with low cutting forces and short chips.
HFP
HFF
For finish turning operations, producing smooth, accurate surfaces. Very good chip control, especially at low depths of cut.
HFS
HFP
For finish to medium turning operations, with optimal chip control over a wide range of cutting conditions and workpiece materials.
HKR
HFS
For finish turning operations. Ground periphery with positive cutting edge ideally suited for high-temp alloys. Micro-finished edge on the ground periphery adds just a slight hone for improved edge integrity and reliability.
HML
HMA
For finish to rough turning operations. Flat-top geometry for machining cast iron.
HMP
HML
For finish to medium turning operations, with a negative, stable cutting edge.
HMR
HMP
For medium to rough turning operations, with reduced cutting forces and improved chip control for high feed rates. Suitable for high metal removal rates and spindling applications.
HMS
HMR
For light to medium rough-turning operations. Excellent choice for steels, difficult-to-machine high-alloy titanium, and aluminum materials. High strength to deal with heavy chip deformation.
HMU
HMS
For medium turning operations. Primarily used with high-temp materials. Utilizes a micro-finished edge preparation to increase edge toughness.
HRH
HMU
For medium turning operations. Medium universal geometry with a soft cutting action due to its positive profile. Versatile application range well suited for boring operations and turning unstable components.
HUF
HRH
For medium to rough turning operations. Outstanding chip control. High edge strength for interrupted cuts, forging skin, or scale. Preferred for all cast iron, such as gray, malleable, and nodular.
HUM
HUF
For finish turning operations, with a positive cutting edge for reduced cutting forces and superior surface quality.
HUR
HUM
For medium turning operations, with a soft-cutting chipbreaker. Used in applications producing varying chip sections, such as profile or copy turning. Good dimensional accuracy. For soft steel materials and stainless steels.
HUR
HUR
For rough turning operations. Improved chip forming and coolant flow for increased tool life. Positive geometry reduces cutting forces and improves depth-of-cut notching resistance. Suitable for stainless steel and smooth machining of steel.
HUR
HM
For medium turning operations. Excellent chip control in various conditions for increased productivity. Variable land reduces cutting loads at high speeds and feeds, promoting stable tool life.
HUR
AL
For finish to medium turning operations. High rake angle and a low resistance cutting edge for extended tool life in continuous cutting of aluminum, non-ferrous metals, and plastics.
HUR
HSF
For finish hard turning operations. Excellent chip control with a unique anti-vibration tip structure. Good dimensional accuracy. Excels at cutting high-hardness materials between 40-62 HRC.
Insert Grades
Choose the grade that best matches your application and workpiece material.
DECODING HAAS GRADES: HTP15
BRAND
H
Haas
APPLICATION
T
Turning
PRIMARY WORKPIECE MATERIAL
P
  P – Steel
  M – Stainless Steel
  K – Cast Iron
  N – Non-Ferrous
  S – High-Temp Alloys
  H – Hardened Materials
  U – Universal Machining
APPLICATION RANGE
10 – Uninterrupted
15 – Light Interrupted
20 – Medium Interrupted
25 – Medium Interrupted
35 – Heavy Interrupted
WEAR RESISTANCE
20
TOUGHNESS
25
30
35
SMOOTH
SURFACE
MEDIUM TO
ROUGH SURFACE
ROUGH
SURFACE
Smooth Cut
Pre-Turned
Lightly
Interrupted
Heavily
Interrupted
CLICK + TO EXPAND
CCET Insert Grades
CLAMPING STYLES
Clamping Styles
M – Multi-Lock System*
• For negative-style inserts
P – Lever-Lock System
S – Screw-On System
• For positive-style inserts
D – Double-Clamp System
• Powerful single-lever screw clamping
• Spring design releases clamp automatically
• Optimized for chip flow
• Eccentric lock pin secures the insert against the side
• Top clamp provides rigid downward clamping
S – Screw-On System
* For multi-lock holders: Rotate the eccentric lock pin counterclockwise until the insert drops on, and then rotate the eccentric pin clockwise to secure the insert against the side of the holder. Install the top clamp to hold down the insert.
Sale Items( 1 )
Clamping Type( 4 )
Insert Style( 5 )The shape of the insert: round, square, diamond, octagonal, etc. The shape of the insert defines the point angle, which determines the strength of the cutting edge, the ability to cut fine features, and the number of indexable cutting edges available.
Primary Workpiece Material( 6 )
Secondary Workpiece Material( 5 )
Grade( 23 )The type of coating on the insert, which determines the toughness and wear resistance of the insert, as well as the types of material for which the insert can be used.
Chipbreaker( 17 )
[IC] Inscribed Circle Diameter( 8 )
[L10] Cutting Edge Length( 15 )
[RE] Corner Radius( 5 )
533 items
02-0078
CNMG431-HFF / CNMG120404-HFF, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0078
RETAIL PRICE: $23.95 $423.95 $126.95 $16.95 $76.95 $177.95 $undefined ($4.79/insert)
02-0079
CNMG431-HUF / CNMG120404-HUF, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0079
$21.97
02-0080
CNMG431-HFF / CNMG120404-HFF, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0080
$21.97
02-0081
CNMG431-HUF / CNMG120404-HUF, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0081
$20.97
02-0082
CNMG432-HMR / CNMG120408-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0082
$20.97
02-0083
CNMG432-HMR / CNMG120408-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0083
02-0084
CNMG432-HML / CNMG120408-HML, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0084
$20.97
02-0085
CNMG432-HML / CNMG120408-HML, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0085
$19.97
02-0086
CNMG432-HUR / CNMG120408-HUR, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0086
02-0087
CNMG432-HUR / CNMG120408-HUR, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0087
$21.97
02-0088
CNMG433-HUR / CNMG120412-HUR, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0088
$19.97
02-0089
CNMG433-HMR / CNMG120412-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0089
$19.97
02-0090
CNMG433-HUR / CNMG120412-HUR, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0090
$19.97
02-0091
CNMG433-HMR / CNMG120412-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0091
$19.97
02-0092
CNMG643-HMR / CNMG190612-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0092
RETAIL PRICE: $44.95 $798.95 $237.95 $31.95 $143.95 $335.95 $undefined ($8.99/insert)
$38.97
02-0093
CNMG643-HMR / CNMG190612-HMR, Carbide Turning Insert, 80° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0093
$38.97
02-0094
DNMG431-HFF / DNMG150404-HFF, Carbide Turning Insert, 55° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0094
RETAIL PRICE: $27.95 $473.95 $140.95 $18.95 $85.95 $198.95 $undefined ($5.59/insert)
$25.97
02-0095
DNMG431-HFF / DNMG150404-HFF, Carbide Turning Insert, 55° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0095
$23.97
02-0096
DNMG431-HUF / DNMG150404-HUF, Carbide Turning Insert, 55° Rhombic, Grade HTP15 - Pack of 5
Part #: 02-0096
$22.97
02-0097
DNMG431-HUF / DNMG150404-HUF, Carbide Turning Insert, 55° Rhombic, Grade HTP25 - Pack of 5
Part #: 02-0097
$25.97
