  2. Measuring & Inspection
  3. Dial Test Indicators
Test Indicators Overview
Get a complete look at the dial test indicator lineup from Haas in this video. Dial test indicators are offered in various ranges for multiple applications. Watch as John takes you through the fundamentals of test indicators.
Test Indicators Details
Dial Test Indicators are a valuable piece of measuring equipment in any shop. These indicators are meant for precise comparisons on surfaces, machines, and part tolerance, or to check the runout on cutting tools. Haas dial test indicators have a magnitude of applications and are especially helpful during setup to ensure that a vise is square or to indicate other parts.
  • Offered in inch (U.S. only) and metric versions
  • 1mm, 2mm, 3mm tip diameters offered
  • Available with ruby tips
  • Long stylus options for tight and hard-to-reach areas
  • Different dial position options for different viewing angles
  • Large dial options available
  • 2x range options for extended travel
  • Metric versions manufactured to DIN2270 standard
  • Inch versions manufactured to ASME B89.1.10M-2001 standard
Don't Forget
Indicator Accessories!
Mag Bases, Holders, Stands & More
SHOP INDICATOR ACCESSORIES
Indicator Videos
Dial Drop Indicators
Large Measuring Range Indicators
Workhorse Dial Indicators
Twice-Range Test Indicators
Getting Accurate Test Indicator Readings
Travel & Test Indicator Differences
Properly Mounting a Travel Indicator
Set a Travel Indicator to Measure a Dimension
System of Measurement( 0 )
Graduation( 0 )
Indicator Type( 0 )
Range( 0 )
Stylus Tip Material( 0 )
Calibration Certificate (Y/N)( 0 )
0 items
Sorry, those parameters return no results..
Try removing a filter and searching again.
