Service Update
Troubleshooting Guide
How-To Procedure
Reference
Instruction Manual
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >*48 CONTIGUOUS UNITED STATES ONLY
Haas Liquid Grease (HLG) cartridges and refills are no longer available. Machines using HLG should be converted to Haas Axis Lubrication Oil, at the earliest convenience.*
You may convert your machine to oil at any time. The process is simple, and is a good opportunity to verify that the machine’s axis lubrication system is working properly. See the conversion procedure linked below.
Order PN 93-3585: AXIS LUBE CONVERSION KIT HLG TO OIL from your local HFO, or through this website. The kit includes a canister of Haas Axis Lubrication Oil, and a 0.020" orifice for the side-mount tool changer (mill) or C-axis (lathe) lube line, if equipped. The conversion kit also includes a software patch containing updated system parameters, which is automatically associated with the machine serial number when the kit is ordered.
Installation of the software patch is not required to convert the axis lube system to oil. The system will operate correctly, after changing a few settings in the control. However, the patch should be installed by a Haas Service Technician at your next scheduled service visit, to optimize the performance of the axis lubrication system.
*Applies to machines built from April 2014 to August 2022 using Haas Liquid Grease (HLG). Machines built after August 2022 use the Haas Axis Lubrication Oil (HALO) system.
Service Update
How-To Procedure
Reference
Instruction Manual
Part #: 93-3584
AXIS LUBE OIL 1GL/3.78L
Customer Rating:
Price: $124.95 ( / unit)
Subscribe & Save: Additional 5% Off
NOTE: EXPEDITED SHIPPING IS NOT AVAILABLE FOR THIS PRODUCT.
NOTE: THE BATTERIES IN THESE PRODUCTS ONLY ALLOW FOR GROUND SHIPPING.
NOTE: Shipments for Haas Tooling and Haas Service parts will be processed and shipped as separate deliveries.
Bulk Pricing
* Discounts will be applied in the cartPrice | |
Quantity | |
Price |
Contact Your Distributor To Purchase
Note: Maximum Quantity Exceeded.
Only {{=qty}} unit(s) in stock. Do you want to proceed with {{=qty}} unit(s)?
In order to subscribe for notifications, you need to have an account.
Already Have an Account? Log In
There was an error when submitting subscription.
Your request has been submitted. We will cancel the notification.
Success! {{=qty}} item(s) added to cart!
Subtotal: {{=sub}}
Related Items
{{=partName}}
Part #: {{=partNum}}
RETAIL PRICE: {{_.forEach(partPrices, function(pprice){ }} {{ }); }}
{{if (allDiscountPrices.length) {}} {{_.forEach(allDiscountPrices, function(dPrice){ }}{{=dPrice.amount}}
{{=acceptCookieText}}
ATTENTION! To increase system performance and reliability, Haas has converted the machine axis lubrication system from grease to oil. Machines using HLG should be converted to Haas Axis Lubrication Oil, at the earliest convenience. See details above.
Average Customer Ratings:
Customer Rating:
If you would like to be notified when there are responses to your question, please log in to your HaasTooling.com account, before submitting your question
Toll Free: (888) 817-4446 / Fax: 805-278-8554
