    • Visualizza tutto
  2. Misurazione e ispezione
  3. Manometri a perno e accessori
  4. Set di manometri a perno meno, 250 pezzi, Grado ZZ, 0,251 - 0,500"
09-0116
09-0116
09-0116
09-0116
09-0116
N. pezzo: 09-0116
PIN GAGES, 250pcs, .251-.500", MINUS
Valutazione del cliente:
Prezzo: 178.95 ( / unità)
107.97
Questo set di manometri a perno meno ZZ viene utilizzato per controllare il limite superiore di una dimensione del foro per verificare che non sia più grande della dimensione prevista.
Tipo Manometro a perno
Numero di pezzi 250
Grado ZZ
Materiale Acciaio duro
Intervallo 0,251 - 0,500 pollici
Durezza Rockwell 60,0 - 63,0 HRC
Standard ASME B89
Tolleranza di fissaggio -0,0002 pollici
[OAL] Lunghezza totale 2,0 pollici\50,0 mm
Peso 23,1 lb \ 10,5 kg
Paese d'origine Cina
Valutazioni medie dei clienti:
5.0
Recensioni totali: 11
Sean
11/27/2024
Excellent value
Found this set on sale, after shopping other brands and waiting due to the prices. This set comes in a fantastic thick protective box, with locking latches, a lid gasket, and well numbered and protected compartments for each pin. Outstanding value, though made in the PRC, as expected at this price.
Idaho Aaron
10/30/2024
Top notch
This set is a great value even when not on sale. I needed some pins and these came up, 2 day delivery and I am really happy with them.
Justin M
09/28/2024
Great Value as Always
Great set - been using mine heavily since I got it, tolerances are right on. As always, cannot beat the price for the quality. Good luck finding a set like this elsewhere for the price!
Scott
09/26/2024
Very happy with this
Very nice gauge pin set at an excellent price! They come in a very well-made case and are clearly labeled.
Lorenzo Derbez
09/25/2024
Awesome Pin Gauge Set
I was really surprised with the quality of the pins and of the box. It is really nice to have the pin set in a well protected box clearly labeled. Pins are really nice, as nice or better than other more known brands.
Jake Johnson
09/22/2024
Excellent Value!
Ty
07/02/2024
Quality gauge pin set
Excellent quality at a very competitive price. Robust case. Great for checking hole location and size.
Nathan
05/30/2024
Great Value for this Gauge Pin Set
I've owned a smaller diameter set for years, and have thought about getting a larger set many times. Haas had a great sale price, so i went ahead and bought this .251-.500" set. The pins are of equal quality to any other ZZ Grade pins I have, and the case is much better than other similar plastic cases. Even if you already have select pins in this size range, I suggest getting the full set. As soon as you have the full set you'll find uses for the extra sizes you now have, and as a bonus you'll have duplicate spare pins on hand for any frequently used sizes you might already own.
Charles Oldham-Fifer
05/26/2024
A reliable pin set
These pins are just what I needed. I paid a great price and got what I needed. I like that the ends are not cut at an angle like some imported pins.
Bud
05/06/2024
pin gauges
Something not used too often but well worth having nice set and affordable.
Carlos Picapito
04/03/2024
Great quality pins
These pins are great quality, comparable to other large well known more expensive brands
Dan Jones
Apr 10 2024
Is there a certificate of accuracy included in these gauge pin sets?
1 Risposte
Haas Tooling Support
Apr 10 2024
Hi Dan, No, it does not come with a certificate of accuracy. This product is manufactured to ASME B89 standard.
09-0116
09-0116
09-0116
09-0116
09-0116
09-0116
