    • Visualizza tutto
Inserti di brocciatura
  2. Serraggio dei pezzi fresatrice
  3. Vise Kits
  4. Confezione da 3, morsa a griffa fissa a stazione singola da 6" (150 mm), apertura da 9" (230 mm), stile a flangia, serraggio dei pezzi Haas di Kurt
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
N. pezzo: 08-1086
HKDX6 KIT, PACK OF 3
Prezzo: 2499.95 ( / unità)
2374.97
MULTI-VISE SETUPS MADE EASY
______________________________________________
Use this 3-pack of Haas Workholding by Kurt 6" (150mm) single-station fixed-jaw vises to create multi-vise setups on a single machine, or to ensure mutliple machines have identical workholding for part consistency and job flexibility. These are the same high-quality DX® Series Kurt vises we all know and love – branded specifically for Haas.
These vises are perfect for tooling up the Haas VF-2YT Pallet Pool, allowing you to set up each pallet with multiple vises for high-volume production. Each pallet’s bolt-pattern allows you to mount all 3 vises side by side, with equal spacing – no need for sub-plates, toe clamps, or custom hold-downs.
These flange-style vises have a 9" (230mm) maximum opening, and feature cast-in stationary jaws for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw, and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
  • Clamp Force Graph
  • KURT LIFETIME WARRANTY
HAI PULITO LA MORSA DI RECENTE?
Mantieni la morsa in funzione senza intoppi! Scopri come pulire e mantenere la morsa.
RISPARMIA -5% ($2,267.91 se acquistato separatamente)
Morsa a griffa fissa a stazione singola da 6" (150 mm), apertura da 9" (230 mm), stile a flangia, Serraggio dei pezzi Haas di Kurt
N. pezzo: 05-0404
PREZZO, SE ACQUISTATO SEPARATAMENTE: $2,519.85
$2,267.91
Quantità: 3
Tipo Kit singolo
Tipo di morsa Manuale
Tipo di morsa Griffa fissa
Numero di stazioni 1
[JW] Ampiezza ganascia 6,0 pollici\150,0 mm
[VO] Apertura morsa 9,0 pollici \ 225,0 mm
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
08-1086
