      • Fiber Laser
      • VF-4SS
GR-712
  1. Vertical Mills
  2. Gantry Series
  3. GR-712
GR-712
    CNY ONLY
CNC Gantry Router with 145" x 85" x 11" travels
The Haas GR Series gantry routers have the power to cut aluminum and other metals, as well as the speed to cut plastics and other light materials. These machines easily handle large sheets of material, or can machine small parts by the thousand. The rigid steel construction of the GR Series provides a very stable cutting platform, and a 1" thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • Rigid-steel construction
  • Traveling guard for chip and coolant containment
  • 1" thick aluminum table
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 10 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Machine Info
  • Specs
AVAILABLE OPTIONS
VIDEOS
CUSTOMER TESTIMONIALS
RELATED PRODUCTS
Standard Features
  • 8100-rpm Spindle
  • 10-Pocket Carousel Tool Changer
  • Chip and Coolant Guard
  • Control Touch Screen
  • Ethernet Interface
  • Power Surge Protection
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Aluminum Table
  • Phone Charging Stand
Warranty
  • 1-Year Standard Warranty
  • 6-Month Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • GR Series Flyer
VIDEOS
Gantry Series Model Overview
These machines easily handle large sheets, or can machine small parts by the thousand. See which Haas gantry machine is right for you!
Haas Second Home Option
There’s no need to lean into your machine to retrieve your tools. In this video, Mark shows us a better way.
Faster tapping with setting 130
Shorten tapping cycles dramatically by speeding up tap retracts. In this Tip of the Day, Mark breaks down setting 130 step-by-step, and explains how it can save you valuable cycle time.
Command a safe tool change position
In this video, Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Display Pictures and Videos on Your Haas Control Using M130
With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your NC program!
Vo-Tech
“The benefit of having the gantry on our shop floor is that it definitely has allowed us to reduce our cycle and setup times. There were large, thin parts that we used to have to make in two setups, even on our a VF-6. We are now able use our gantry, which has an 8 x 10 ft envelope, and machine those parts all in one setup, which is great.”
- Adam Furman , Operations Manager, Vo-Tech
Customer Spotlight - Airmate Company, Inc. - Gantry Router
Airmate Company, Inc. recently switched from traditional CNC routers to Haas CNC Gantry Routers and vertical machining centers to machine parts for their material handling and automotive customers. According to Adam Holman, General Manager at Airmate, the switch to Haas has reduced setup times and cycle times, while increasing the flexibility on their shop floor to machine large and small parts on the same equipment.
RELATED PRODUCTS
SMALLER WORK ENVELOPE
Haas GR-510
GR-510
CNC Gantry Router with 121" x 61" x 11" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 10 Tool Capacity
    CNY ONLY
Learn More Build & Price
Travels S.A.E METRIC
X Axis 145.00 in 3683 mm
Y Axis 85.00 in 2159 mm
Z Axis 11.00 in 279 mm
Spindle Nose to Table (~ max) 13.5 in 343 mm
Spindle Nose to Table (~ min) 2.5 in 64 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 48.0 ft-lbf @ 1500 rpm 65.0 Nm @ 1500 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper CT or BT 40 CT or BT 40
Table S.A.E METRIC
Length 144.0 in 3658 mm
Width 72.0 in 1829 mm
Thickness 1.0 in 25 mm
Max Weight on Table (evenly distributed) 6000 lb 2722 kg
Between Columns 86.0 in 2184 mm
Feedrates S.A.E METRIC
Max Cutting 800 ipm 20.3 m/min
Rapids on X 800 ipm 20.3 m/min
Rapids on Y 2100 ipm 53.3 m/min
Rapids on Z 1100 ipm 27.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2520 lbf 11210 N
Max Thrust Y 1020 lbf 4537 N
Max Thrust Z 2050 lbf 9119 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 10 10
Max Tool Diameter (full) 3.5 in 89 mm
Max Tool Weight 12.0 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 15.0 hp 11.2 kW
Domestic Pallet 226.0 in x 137.0 in x 116.0 in 575 cm x 348 cm x 295 cm
Export Crate 226.0 in x 137.0 in x 119.0 in 575 cm x 348 cm x 303 cm
Weight 24000 lb 10887.0 kg
Domestic Pallet w/EC Option 226 in x 137 in x 116 in 575 cm x 348 cm x 295 cm
Export Crate w/EC Option 226 in x 137 in x 118 in 575 cm x 348 cm x 300 cm
Weight w/EC Option 24200 lb 10977 kg
Domestic Pallet w/EZ24 Option 226 in x 137 in x 124 in 575 cm x 348 cm x 315 cm
Export Crate w/EZ24 Option 226 in x 137 in x 127 in 575 cm x 348 cm x 321 cm
Weight w/EZ24 Option 24600 lb 11159 kg
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
Build & Price
Get Started
Need More Information?
