CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
The Air Blast option for DC series machines supplies high-pressure air through an adjustable Loc-Line that can be positioned to clear chips safely and automatically during machining, or blow chips and coolant out of pockets. It can also be used to blow off parts and workholding at the end of a cycle. Activated by M code, the air blast is turned on and off via the part program.
Toll Free: (888) 817-4446 / Fax: 805-278-8554
