Automatic Coolant Refill (COOLANT REFILL)
Product Image
GET QUOTE
Starting Price: US$1,695 CNY ONLY
No more wasting time mixing coolant
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
Stop hauling buckets of coolant and water around your shop, and cleaning up spills along the way. Stop wasting time measuring and mixing to get the right ratio. Forget all those hassles and save a ton of time. The Haas Automatic Coolant Refill System monitors the machine coolant level, and automatically adds correctly mixed coolant to the tank. This saves the machine operator valuable time for other tasks, such as keeping the machine running and producing parts. The Haas Automatic Coolant Refill System is easy to operate, reliable, and inexpensive.
NOTE: Do not use powders, anti-foaming agents, or chlorine, as they will contaminate and clog the system. Use only water and liquid concentrate.
  • Supplies mixed coolant for long periods of unattended operation between concentrate refills
  • Manage your coolant consumption, concentration, and refill intervals – all via definable settings
  • Yields up to 95 gallons of mixed coolant at a 6% ratio
FEATURES:
  • Automatically monitors the machines coolant level
  • Mixes shop water supply with coolant concentrate at user-controlled ratios
  • Adds correctly mixed coolant at a specified concentration, as needed
  • Saves time by keeping the machine operator making parts, not mixing coolant
NOTE: The stand-alone mount is needed for machines with built-in coolant tanks, or machines without sufficient clearance for the coolant tank mount.
STAND-ALONE MOUNT
COOLANT TANK MOUNT
SERVICE DOCUMENTS
Troubleshooting Guide
Coolant Refill Option - Troubleshooting Guide
Videos
Coolant Refill - Troubleshooting
The Automatic Coolant Refill System
How-To Procedure
Coolant Refill - Calibration
Coolant Refill - Installation - AD0171
Coolant Refill - Operation - Maintenance - AD0172
VIDEOS
The Haas Automatic Coolant Refill System is designed to enhance the productivity of your shop by simplifying the way you make coolant. Our goal was to create an option that takes all the calculation, chemistry, and mixing out of the process. In this video, Andrew and Don go over some of the option’s key points, and explain why it’s an essential upgrade for your shop – saving you time and making you money.
Need More Information?
