Troubleshooting Guide
How-To Procedure
Instruction Manual
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
This sturdy tubular steel stand elevates your Haas cobot 24" (610 mm) above the floor to provide additional reach, depending on your application. The top mounting plate has multiple bolt-hole patterns to accept all Haas cobots.
How-To Procedure
Instruction Manual
System of Measurement | Universal - ANSI, ISO |
Type | Pedestal |
Robot Series | HC5 (5kg x 800mm), HC10 (10kg x 1000mm), HC15 (15kg x 1300mm) |
Material | Steel |
[a] Dimension | 10.551 in \ 268.0 mm |
[b] Dimension | 8.976 in \ 228.0 mm |
[c] Dimension | 9.449 in \ 240.0 mm |
[d] Dimension | 8.465 in \ 215.0 mm |
[OAL] Overall Length | 11.8 in \ 300.0 mm |
[OAW] Overall Width | 11.8 in \ 300.0 mm |
[OAH] Overall Height | 24.0 in \ 609.6 mm |
Weight | 77.2 lb \ 35.0 kg |
Toll Free: (888) 817-4446 / Fax: 805-278-8554
