Troubleshooting Guide
How-To Procedure
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
VIDEOS
CUSTOMER TESTIMONIALS
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 6+1 pallet pool for the EC-400 is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires optional 50+1 or 100+1 side-mount tool changer. The Pallet Pool must be anchored for proper operation.
*NOTE: Due to continual design improvements, 3D models and layout drawings may not be accurate to the latest production model.
How-To Procedure
The completely redesigned EC-400 was specifically engineered for high-volume production and unattended operation. Pair the EC-400 with our 6+1 Pallet Pool and get true “lights out” production capabilities.
“We are primarily a job shop, but we also have our own product line, which makes us somewhat special. We had a customer that had a high demand for parts, so we purchased an EC-400. I saw the 6+1 Pallet Pool that was available, and it was a no brainer. The machine ran non-stop, with no hiccups. We had all 7 pallets loaded up at night when our workers would go home for the day, and it would run all night. Our Pallet Pool got us ahead of schedule, and let us take on more work. Our EC-400 has probably saved about 25% on our runtime. We have 15,000-rpm, faster feeds and speeds, much faster tool changes, finishes are great, accuracy is very good, and repeatability is no problem.”
– Steve Phillips, President
400 mm Twin-Pallet HMC with 22" x 25" x 22" travels
High-volume production, unattended operation
The Pallet Pool option available on Haas EC-series Horizontal Machining Centers is designed for high-volume production and unattended operation. This manufacturing solution also excels at high-mix/low-volume part runs, because the user can assign a specific part program for each pallet. Each time that pallet is moved into the machining area, the control will automatically call the assigned part program.
INCH | METRIC | |
Number of Stations | 6 + 1 | 6 + 1 |
Number of Pallets (includes the 2 pallets from the machine) |
7 |
7 |
Pallet Length |
15.7 in | 400 mm |
Pallet Width |
15.7 in |
400 mm |
Maximum Pallet Load |
500 lb |
226.8 kg |
Maximum Part Diameter (Workholding + Workpiece) | 22.0 in |
559 mm |
Maximum Part Height (Workholding + Workpiece) | 35.0 in | 889 mm |
Shipping Dimensions (Domestic) L x W x H | 180" x 92" x 92" | 457 x 234 x 234cm |
Shipping Dimensions (Export) L x W x H | 182" x 94" x 98" | 462 x 239 x 249 cm |
Shipping Weight | 6260 lb | 2839 kg |
Pallet Schedule Table Interface
The simplified Pallet Schedule Table (PST) controls pallet scheduling functions from a dedicated screen. Pallets can be scheduled individually according to priority and sequencing requirements.
We developed a new M-code for use with Automatic Pallet Changers. M199 is typically used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed (PALLET MODE), the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, even a mid-program start, and continue uninterrupted machining, as long as pallets are scheduled.
Pallet Changer | S.A.E | METRIC |
Pallet Quantity | 7 | 7 |
Pallet Length | 15.70 in | 400 mm |
Pallet Width | 15.70 in | 400 mm |
Max Pallet Load | 500 lb | 226.8 kg |
Max Part Diameter | 22.0 in | 559 mm |
Max Part Height | 35.0 in | 889 mm |
Dimensions - Shipping | S.A.E | METRIC |
Domestic Pallet | 138.0 in x 80.0 in x 92.0 in | 351 cm x 203 cm x 234 cm |
Export Crate | 138.0 in x 80.0 in x 92.0 in | 351 cm x 203 cm x 234 cm |
Weight | 5080 lb | 2305.0 kg |
Toll Free: (888) 817-4446 / Fax: 805-278-8554
