CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >This high-performance 10,000-rpm spindle for 50-taper machines is driven by a 60 hp vector drive system that provides higher power throughout the rpm range. It uses a Haas-built two-speed gearbox to provide a wide constant horsepower band, good low-speed torque for heavy cuts, and higher torque throughout the range above 500 rpm. Haas gears are CNC machined and hobbed out of alloy steel, heat treated to 60 Rc, and then precision ground to AGMA Class 13 quality. Note: Speeds higher than 7000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
DOCUMENTS
AVAILABLE ON THESE MACHINES
Spindle | S.A.E | METRIC |
Max Rating | 60.0 hp | 44.7 kW |
Max Speed | 10000 rpm | 10000 rpm |
Max Torque | 350.0 ft-lbf @ 900 rpm | 475.0 Nm @ 900 rpm |
Drive System | 2-Speed Gearbox | 2-Speed Gearbox |
Taper | CT or BT 50 | CT or BT 50 |
Bearing Lubrication | Air / Oil Injection | Air / Oil Injection |
Electrical Specification | S.A.E | METRIC |
Spindle Power | 60.0 hp | 44.7 kW |
Input AC Voltage (3 Phase) - Low | 220 VAC | 220 VAC |
Full Load Amps (3 Phase) - Low | 105 A | 105 A |
Input AC Voltage (3 Phase) - High* | 440 VAC | 440 VAC |
Full Load Amps (3 Phase) - High* | 53 A | 53 A |
Note:
Toll Free: (888) 817-4446 / Fax: 805-278-8554
