Troubleshooting Guide
How-To Procedure
Reference
Instruction Manual
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 20,000-rpm spindle features an integral motor design that provides high speed capability in a compact package. The HSK-63F taper provides high rigidity and high stability for high-speed, extended-reach machining applications. The HSK (Hohl Shaft Kegel, or hollow-shank taper) tooling provides dual contact between the taper and the spindle face, providing a very rigid connection that offers excellent axial and radial accuracy, especially at high spindle speeds.
NOTE: This spindle does not have brakes on the B and C axis. For more rigid 3+2 machining, consider the optional HSK-A63 spindle, which has B- and C-axis brakes.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
How-To Procedure
Reference
Instruction Manual
Note:
Toll Free: (888) 817-4446 / Fax: 805-278-8554
