CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 8100-rpm spindle for 40-taper machines uses a Haas-built two-speed gearbox to provide a wide constant power band, good low-speed torque for heavy cuts, and higher torque throughout the range above 500 rpm. Haas gears are CNC machined and hobbed out of alloy steel, heat treated to 60 Rc, and then precision ground to AGMA Class 13 quality.
Note:
Toll Free: (888) 817-4446 / Fax: 805-278-8554
