Service Update
Troubleshooting Guide
How-To Procedure
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
SERVICE DOCUMENTS
VIDEOS
CUSTOMER TESTIMONIALS
AVAILABLE ON THESE MACHINES
Our finishing sub-spindle for ST-10 through ST-28 turning centers – including Y-axis models – will not only make you more productive, but will also provide new options for finishing the 2nd-op side of your parts.
This affordable A2-5 spindle is equipped with a 5.3-inch hydraulic chuck, and will fully synchronize with the main spindle to provide effortless “in-cycle” part handoff. This allows you to finish-off the “other half” of your part in a single setup – simply load up your raw workpiece, and the next time you open the door, you’ll have a finished part. A built-in part ejector propels the finished part into the optional parts catcher for automated operation.
Note: Not compatible with the VDI or BOT turret, or the tailstock option. The sub-spindle is compatible with the APL; however, the APL can only load/unload parts from the main spindle. Availability may vary by region.
Service Update
How-To Procedure
Watch live tool milling, drilling, and tapping, featuring our A2-5 finishing sub-spindle and ST-10Y turning center.
See just how easy it is to program your lathe sub-spindle. In this Tip of the Day, Mark walks you through how to use G14 and how to set up your tools when using a sub-spindle.
In this Tip of the Day, Mark shows how to synchronize the spindles on your Haas dual-spindle lathe. Learn how to hand off parts from the main to the sub-spindle, how to orient the chucks, and how to be sure the RPM on each spindle matches. With a great step-by-step explanation combined with some great animations and close-up shots of the spindles, you will walk away from this video an expert in spindle synchronization!
Recently, American Torch Tip installed a turning cell with three Haas ST-20Y CNC lathes with sub-spindles, each with automation for lights-out production. Two of the ST-20Ys are loaded by Haas Automatic Parts Loaders, while the third is loaded by a Haas Robot Package. Learn how this installation is helping a leading manufacturer of torches gain a competitive edge.
“We finally bought one . . . [Robot Package] and that was nice, because it was all plug-and-play.” – Jack Walters, President - American Torch Tip Co.
Sub-Spindle Benefits:
Sub-Spindle programming is made simple by the Haas control. Forget about having to program the Z-axis in the positive direction. Simply program the Sub-Spindle operations the same way you would for the Main Spindle, insert G14 (Secondary Spindle Swap) at the Sub-Spindle Tool Call in the program, and the control does everything for you – from turning on the spindle in the correct direction, to opening and closing the chuck, to turning on the coolant, and more.
The Main and Sub-Spindle can fully synchronize, so you can pass-off a part with the chucks turning. The Sub-Spindle also is capable of phasing (orientation), so you can grip parts with odd shapes.
A dedicated active G-code display on the control lets you know the status of both spindles at all times.
The A2-5 Finishing Sub-Spindle Option requires the BMT45 turret option. The BMT45 turret is standard on the ST-10Y/ST-15Y lathes.
When the Finishing Sub-Spindle option is ordered, the Included Tool Kit is replaced by a new one, as described below. The Tool Kit is compatible with BMT45 Turret.
Inch version of the BMT45 Sub-Spindle Tool Kit (BMT45SKIT) contains the following:
Metric version of the BMT45 Sub-Spindle Tool Kit (BMT45SKITM) contains the following:
The A2-5 Finishing Sub-Spindle Option requires the BMT65 turret option, with or without live tooling. The BMT65 turret is standard on all Y-axis lathes.
When the Finishing Sub-Spindle option is ordered, the Included Tool Kit is replaced by a new one, as described below. The Tool Kit is compatible with the BMT65 Turret.
Inch version of the BMT65 Tool Kit contains the following:
Metric version of the BMT65 Tool Kit contains the following:
A very high-volume production setup common with sub-spindle lathes involves a bar feeder and a parts catcher. This trio of options allows for extended periods of unattended parts machining.
This is why we include a Parts Ejector with every Sub-Spindle Option. The Parts Ejector inserts directly into the bore of the drawbar, and provides a very simple way to eject a finished part into the parts catcher chute, for continual machine operation without opening the door. The ejector features a removable end piece (push plug) that can be customized to fit your application.
Note:
Sub-Spindle | S.A.E | METRIC |
Chuck Size | 5.3 in | 135 mm |
Spindle Nose | A2-5 | A2-5 |
Max Speed | 6000 rpm | 6000 rpm |
Max Sync Speed w/Main Spindle | 4800 rpm | 4800 rpm |
Chuck Throat | Ø 1.30 in x 1.37 in DEEP | Ø 33.0 mm x 34.8 mm DEEP |
Drawbar Bore (NON-THROUGH) | Ø 1.00 in x 4.50 in DEEP | Ø 25.4 mm x 114.3 mm DEEP |
Spindle Bore (without chuck and drawbar installed) | 1.50 in | 38.1 mm |
Integrated Brake Torque | 17 ft-lbf | 23 N/m |
Spindle Orientation Accuracy (Requires SO) | ± 0.02 ° | ± 0.02 ° |
Rapids (B-axis) | 400 ipm | 10 m/min |
Toll Free: (888) 817-4446 / Fax: 805-278-8554
