CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
This rectangular grid fixture plate mounts to the B90 side of the UMC trunnion to simplify mounting of vises or other workholding for performing first or last operations.
System of Measurement | Universal - ANSI, ISO |
Machine Models | UMC-1000, UMC-750, UMC-500 |
Pallet Pool Compatible | Yes |
Plate Style | Rectangle |
Plate Design | Grid |
Material | Steel |
[OAL] Overall Length | 15.748 in \ 400.0 mm |
[OAW] Overall Width | 8.465 in \ 215.0 mm |
[OAH] Overall Height | 0.748 in \ 19.0 mm |
Base Length | 15.748 in \ 400.0 mm |
Base Width | 8.465 in \ 215.0 mm |
[BT] Base Thickness | 0.748 in \ 19.0 mm |
[a] Dimension | 5.874 in \ 149.2 mm |
[b] Dimension | 4.0 in \ 101.6 mm |
[c] Dimension | 0.984 in \ 25.0 mm |
[d] Dimension | 5.5 in \ 139.7 mm |
[e] Dimension | 1.969 in \ 50.0 mm |
[TP1] Thread | M12x1.75 |
Parallelism | 0.002 in \ 0.051 mm |
Weight | 26.8 lb \ 12.2 kg |
Toll Free: (888) 817-4446 / Fax: 805-278-8554
