      • Fiber Laser
      • VF-4SS
      • Fixture Clamps
G-code, M-code, and Setting
Service Home M07 Shower Coolant On
M07 starts the optional shower coolant. M09 stops the shower coolant and also stops the standard coolant. The optional shower coolant stops automatically before a tool change or a pallet change. It automatically starts again after a tool change if it was ON before a tool change command.
NOTE
Some machines use optional relays and optional M-codes to command shower coolant, such as M51 on and M61 off. Check your machine configuration for the correct M-code programming.
