11. DC-Series - Maintenance
DC-Series Operator's/Service Manual
  • 0. DC-Series - Table of Contents
  • 1. DC-Series - Introduction
  • 2. DC-Series - Legal Information
  • 3. DC-Series - Safety
  • 4. DC-Series - Installation
  • 5. DC-Series - Operation / Tool Changer
  • 6. DC-Series - Control Icons
  • 7. DC-Series - Programming
  • 8. DC-Series - G-Codes
  • 10. DC-Series - M-Codes
  • 10. DC-Series - Settings
  • 11. DC-Series - Maintenance
  • 13. DC-Series - Spindle Chiller
  • 14. DC-Series - Spindle Motor
  • 11.1 DC-Series Maintenance Schedule
  • 11.2 DC-Series - Axis Lubrication Pump Maintenance
  • 11.3 DC-Series - Air Regulator Maintenance
  • 11.4 DC-Series - Spindle Chiller Maintenance
  • 11.5 DC-Series - Service Parts List
DC Tool Changer
Maintenance Item Interval
Clean the chips from the tool changer.
Weekly
Inspect motor and gearbox.
Monthly
Grease the guide rails.
Monthly
Grease the extractor fingers.
Monthly
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Clean vector drive air vents / filter.
Monthly
Inspect windows for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Air Regulator
Inspect Outgoing Air Pressure.
Weekly
Inspect/Refill Air Lubrication Level.
Monthly
Clean/Replace Air Filter
Six Months
Probe System
Check the probe batteries.
Six Months
Check probe calibration.
Six Months
Inspect the oil level.
Annually
Replace the oil.
Two Years
Inspect the A-Axis counterbalance cylinder for oil leaks. Two Years
Replace the A-Axis counterbalance cylinder.
Four Years
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Clean the standard coolant filter.
Six Months
Verify coolant refill is operating correctly.
Six Months
Through Spindle Coolant (TSC) 300/1K PSI
Clean the TSC-300 / 1K Pump Filter
Six Months
Six Months
Verify the Auto Clean system is operating correctly.
Six Months
Spindle Chiller
Inspect Fluid Tank Level.
Daily
Fill Fluid Tank. As Required
Clean Air Inlet Filter.
Weekly
Inspect/Clean Air Outlets.
Weekly
Spindle
Clean and lubricate the spindle taper.
As Required
Spindle drawbar force measurement.
Annually
Inspect lubrication tank level.
Monthly
Perform Axis Lubrication Test.
Six Months
Clean the filter inside the oil reservoir.
Annually
Clean the Auxiliary Filter Annually
Tooling
Grease Pull Studs.
As Required
  1. Oil Tank Cap
  2. Oil Inlet Filter
  3. Reservoir
  4. Level Switch
  5. Gear Pump
  6. Pressure Relief Valve
  7. Dump Valve
  8. Elbow Adapter
  9. Pressure Gauge
  10. Power Indicator
Monthly
Six Months
Annually
Clean the Auxiliary Filter. Annually
Fill the tank with 93-2365 OIL SYNTHETIC 75W-90 to the MAX fill line[1].
 Note: You must fill the reservoir tank to the fill line [1] each time you fill the tank.
The filter for the axis lubricant must be cleaned. To access the filter, unfasten the bottom of the axis lubricant filter [1] from the top cap [2] that is mounted in the lube panel. Then, remove the filter element [3] and clean. If it cannot be cleaned sufficiently, replace the filter element.
The air regulator requires monitoring and maintenance of the following parts:
  1. Pressurized air filter
  2. Pressurized air canister
  3. Air lubrication canister
  4. Air inlet
  5. Air outlet
DC-Series Air Regulator Maintenance
Air Regulator
Weekly
Monthly
Clean/Replace Air Filter. Six Months
The pressurized air filter needs to be cleaned whenever the air lubrication is refilled. To remove the air filter, unfasten the air canister [1] and the umbrella base [2]. Clean the filter or have it replaced if cannot be cleaned sufficiently.
NOTE: When re-installing the filter, the narrow end must be oriented up as shown in the image.
Prior to refilling the air lubrication canister, clean out the canister [3] using a non-organic solvent such as dishwashing soap. Once cleaned, refill the canister with air lubricant. Use Mobil DTE 24 Ultra as lubricant for the air regulator - (93-2546)
Inspect the inlet and outlet ports for leaks or damage whenever the air regulator is disconnected from the air supply.
This section gives details about the required maintenance for the Spindle Chiller unit [1].
Spindle Chiller
Daily
Weekly
Weekly
DC-Series Spindle Chiller Maintenance
This image shows the key components of the Spindle Chiller:
Front of Chiller:
  • Temperature Control
  • Flow Indicators
  • Air Inlet Filter
Back of Chiller:
  • Fluid Tank Inlet
  • Alarm Terminal
  • Cooling Inlet/Outlet
  • Fluid Level Gauge
  • Air Outlets
Inspect the fluid tank level by looking at the fluid level gauge located on the back of the spindle chiller [2]. To add fluid to the tank, remove the cap to the inlet at the top of the unit, and fill the tank with a mixture of 30% ethylene glycol and 70% dionized water until the gauge reads the level is at the top of the NORMAL [3] or at the FULL level.
To clean the air inlet filter, remove the grate to gain access to the filter unit. From there, remove the filter screen so that any dust or debris can be picked out of the filter. If necessary, wash the filter using water to get rid of contaminants.
Make sure that the air outlets are clear of dust and debris. It is also recommended to allow a clear area of 12 inches directly behind the air outlet vents. This will allow for proper air circulation in the system.
HAAS DC-Series - Service Parts List
Revision C - 03/2026
Machines Part Number Description
DC-1/30T 93-4412 COUPLING X/Y-AXIS DC-1
93-4413 COUPLING Z-AXIS DC-1
93-4405 BEARING ANG CONT X/Y-AXIS DC-1
93-4406 BEARING DEEP GROOVE X/Y-AXIS DC-1
93-4407 BEARING ANG CONT Z-AXIS DC-1
93-4408 BEARING DEEP GROOVE Z-AXIS DC-1
93-4455 TOOL CHANGER CAM FOLLOWER DC-1
93-4415 LG X-AXIS DC-1
93-4416 LG Y-AXIS DC-1
93-4417 LG Z-AXIS DC-1
93-4418 BSCREW X-AXIS DC-1
93-4419 BSCREW Y-AXIS DC-1
93-4424 BSCREW Z-AXIS DC-1
93-4409 WAYCVR TELE LEFT X-AXIS DC-1
93-4425 WAYCVR TELE RIGHT X-AXIS DC-1
93-4410 WAYCVR TELE FRONT Y-AXIS DC-1
93-4426 WAYCVR TELE REAR Y-AXIS DC-1
93-4460 CONDUIT X-AXIS MOTOR CABLE BRAIDED DC-1
93-4588 EYE BOLT M30-3.5 X 21MM DC-1
93-4685 ENCLOSURE ROOF SERVICE DC-1
93-4629 COOLANT TANK MESH PLATE DC-1
93-4630 FERRULE LUBE LINE DC-1
93-4631 FITG 4NPT TO JIC 12 ADAPTER CLNT DC-1
93-4632 BT40 MAGAZINE REDUCER DC
93-4633 SPINDLE DOG DC-1
93-4672 PENDANT PANEL SUPPORT BRACE DC-1
93-4707 LUBE FILTER STRAIGHT FITTING DC-1
93-4708 LUBE PUMP 90DEG FITTING DC-1
93-4709 X-AXIS CONDUIT MOUNT DC-1
93-5066 WAYCVR TELE Z-AXIS DC-1 30T
DC-1/30T or DC-2/30T 93-3945 SPINDLE 30T INLINE 20K W/DB DC-1
93-4454 BEARING TOOL CHANGER NEEDLE DC-1
93-4456 BEARING TOOL CHANGER ROLLER DC-1
93-4402 LUBE PUMP DC-1 SVC
93-4403 AIR REGULATOR UNIT DC-1 SVC
93-4404 OIL DISTRIBUTION MANIFOLD DC-1 SVC
93-4457 TOOL HOLDER ASSY 30T TOOL CHANGER DC-1
93-4458 DC-1 TOOL CHANGER MOTOR REPLACEMENT
59-2245 SPINDLE CHILLER DC-1
93-4610 GEARBOX ASSY 30T SVC KIT DC-1
93-4762 CLNT TANK THERMOMETER/LEVEL SNSR DC-1/2
93-4763 TOOL CHANGER FRONT PLASTIC COVER DC-1/2
93-4830 WINDOW SIDE PC SVC KIT DC-1/2
93-4977 DOOR MAGNET SVC DC-1/2
93-4978 LEVELING PAD SVC DC-1/2
93-5068 TOOL CHANGER REAR PLASTIC COVER DC-1/2
DC-1-40T 93-4972 SPINDLE 40T INLINE 15K W/DB DC-1
93-4979 TOOL HOLDER ASSY 40T TOOL CHANGER DC-1
DC-2 93-4872 COUPLING X/Y/Z-AXIS DC-2
93-4873 LG X-AXIS DC-2
93-4874 LG Y-AXIS DC-2
93-4875 LG Z-AXIS DC-2
93-4876 BSCREW X-AXIS DC-2
93-4877 BSCREW Y-AXIS DC-2
93-4878 BSCREW Z-AXIS DC-2
93-4764 HOSE 3/4 ID HYD STEEL BRAIDED 9FT DC-2
93-4673 WAYCVR TELESCOPE LEFT X-AXIS DC-2
93-4674 WAYCVR TELESCOPE RIGHT X-AXIS DC-2
93-4765 HOSE 3/4 ID HYD STEEL BRAIDED 17FT DC-2
93-5287 ENCL BTM LEFT/RIGHT SIDE SKIRT DC-2
93-5288 ENCL BTM RIGHT SIDE SKIRT DC-2
93-5289 ENCL BTM FRONT SKIRT DC-2
93-5309 COUPLER Z-AXIS 20-24 W/ KEY DC-1/40 DC-2
93-6123 WAYCVR TELE FRONT Y-AXIS DC-2
93-6124 WAYCVR TELE REAR Y-AXIS DC-2
DC-4/40 93-5308 SPINDLE 40T INLINE 15K W/DB SVC KIT DC-4
93-5472 TRP BOOSTER CYLINDER DC-4/40
93-5486 COUPLER X-AXIS 38-24 W/ KEY DC-4/40
93-5485 COUPLER Y-AXIS 28-24 W/ KEY DC-4/40
93-5484 COUPLER Z-AXIS 20-24 W/ KEY DC-4/40
93-5492 BSCREW SUPPORT BEARING X-AXIS DC-4/40
93-5493 BSCREW SUPPORT BEARING Y-AXIS DC-4/40
93-5494 BSCREW SUPPORT BEARING Z-AXIS DC-4/40
93-5495 LG X-AXIS DC-4/40
93-5496 LG Y-AXIS DC-4/40
93-5497 LG Z-AXIS DC-4/40
93-5498 BSCREW X-AXIS DC-4/40
93-5499 BSCREW Y-AXIS DC-4/40
93-5500 BSCREW Z-AXIS DC-4/40
93-5483 WAYCVR BELLOW RIGHT X-AXIS DC-4/40
93-5482 WAYCVR BELLOW LEFT X-AXIS DC-4/40
93-5481 WAYCVR BELLOW Z-AXIS DC-4/40
93-5480 WAYCVR TELE FRONT Y-AXIS DC-4/40
93-5479 WAYCVR TELE REAR Y-AXIS DC-4/40
93-5507 CBL CARRIER 45X100X1200MM Z-AXIS DC-4/40
93-5506 CBL CARRIER 45X175X2350MM X-AXIS DC-4/40
93-5509 CLNT TANK CHIP BIN DC-4/40
