machines
Main Menu
Vertical MillsVertical Mills View All
- Vertical Mills
- VF Series
- Universal Machines
- VR Series
- VP-5 Prismatic
- Pallet-Changing VMCs
- Mini Mills
- Mold Machines
- High-Speed Drill Centers
- Drill/ Tap/ Mill Series
- Toolroom Mills
- Compact Mills
- Gantry Series
- Extra-Large VMC
- Double-Column Mills
- Desktop Mill
- Control Simulator
- Mill Automatic Parts Loader
- Compact Automatic Parts Loader
Multi-Axis SolutionsMulti-Axis Solutions View All
LathesLathes View All
Horizontal MillsHorizontal Mills View All
Rotaries & IndexersRotaries & Indexers View All
Automation SystemsAutomation Systems View All
Desktop MachinesDesktop Machines View All
QUICK LINKS Special Series Special SeriesSHOPPING TOOLSWANT TO TALK TO SOMEONE?A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR > -
Options
Main Menu
SpindlesSpindles View All
Tool ChangersTool Changers View All
4th- | 5th-Axis4th- | 5th-Axis View All
Turrets & Live ToolingTurrets & Live Tooling View All
ProbingProbing View All
Chip & Coolant ManagementChip & Coolant Management View All
The Haas ControlThe Haas Control View All
Product OptionsProduct Options View All
Tooling & FixturingTooling & Fixturing View All
WorkholdingWorkholding View All
5-Axis Solutions5-Axis Solutions View All
Why Haas
Main Menu
Service
Main Menu
- Videos Main Menu
Main Menu
Haas Tooling
Main Menu
- Haas Tooling
Winner's CircleWinner's Circle Shop All
ClearanceClearance Shop All
Today’s Hot DealsToday’s Hot Deals Shop All
Measuring & InspectionMeasuring & Inspection Shop All
- Probe Kits & Accessories
- Edge & Center Finders
- Comparative Measuring Gauges
- Height Gauges
- Calipers
- Threaded Plug & Ring Gauges
- Gauge Blocks
- Pin Gauges
- Drop Indicators
- Dial Test Indicators
- Bore Gauges
- Indicator Accessories
- V Blocks
- Setup Blocks
- Depth Measuring
- Micrometers
- Micrometer Accessories
- Micrometer Kits
- Bore Gauge Kits
- Starter Kits
- Indicator Kits
- Caliper Kits
- Toolholder Check Station
- Height Setters
Cobots & AccessoriesCobots & Accessories Shop All
Shop SupportShop Support Shop All
Mill ToolholdingMill Toolholding Shop All
Mill ToolingMill Tooling Shop All
- Shell Mill Bodies
- Milling Inserts
- End Mills
- Chamfer Mills & Inserts
- Indexable End Mill Bodies
- Ball End Mills
- Chamfer End Mills
- Roughing End Mills
- Indexable Ball End Mills & Inserts
- Shell Mill Kits
- Chamfer Mill Kits
- Indexable End Mill Kits
- Dovetail Cutters
- Indexable Dovetail Cutters
- Engraving End Mills
- Rotary Burrs / Die Grinding Bits
- Keyseat Cutters
- Corner Rounding End Mills
- Slot Mill Bodies
Boring SystemsBoring Systems Shop All
Mill WorkholdingMill Workholding Shop All
Lathe ToolholdingLathe Toolholding Shop All
Lathe ToolingLathe Tooling Shop All
- Cut-Off Tool Blocks & Blades
- Cut-Off Tooling Kits
- Turning Inserts
- Grooving & Cut-Off Tools
- Internal (ID) Grooving & Threading Tools
- Threading Inserts
- Threading Tools
- Boring Bars / Internal (ID) Turning Tools
- External (OD) Turning Tools
- Cermet Turning Inserts
- CBN Turning Inserts
- Haas Notch Grooving & Threading Inserts
- Haas Notch Grooving & Threading Tools
- Micro Turning Tools
Lathe WorkholdingLathe Workholding Shop All
Package KitsPackage Kits Shop All
- Chip Clearing Fan Kits
- Cutting Tool Kits
- Cut-Off Tool Block & Blade Kits
- Drill & Tap Kits
- Indexable Drilling Kits
- Shell Mill Kits
- Chamfer Mill Kits
- Rotary Tool Holder & Tool Chuck Kits
- Lathe Starter Kits
- Workholding Kits
- Rotary Vise Kits
- Vise Kits
- 3-Jaw Chuck Kits for Mills
- Tombstone Kits
- Reduction Sleeve Kits
- Automated Workholding Kits
- Measuring & Inspection Kits
- Starter Kits
- Bore Gauge Kits
- Caliper Kits
- Indicator Kits
- Micrometer Kits
ER Collets & ChucksER Collets & Chucks Shop All
HolemakingHolemaking Shop All
ThreadingThreading Shop All
BroachingBroaching Shop All
TombstonesTombstones Shop All
Manual Chucks For MillingManual Chucks For Milling Shop All
Deburring & AbrasivesDeburring & Abrasives Shop All
Tool Presetter & Heat ShrinkersTool Presetter & Heat Shrinkers Shop All
Tool StorageTool Storage Shop All
Machine MaintenanceMachine Maintenance Shop All
Tooling AccessoriesTooling Accessories Shop All
Apparel & AccessoriesApparel & Accessories Shop All
Cobots & Accessories Mill Toolholding Mill Cutting Tools Boring Systems Mill Workholding Lathe Toolholding Lathe Cutting Tools Lathe Workholding Package Kits ER Collets & Chucks Holemaking Threading Broaching Tombstones & Kits Manual Chucks For Milling Deburring & Abrasives Tool Presetter & Heat Shrinkers Storage & Handling Machine Maintenance Tooling Accessories Apparel & Accessories Measuring & Inspection Winner's Circle Winner's Circle Clearance -
Haas Service Parts
Main Menu
- Haas Service Parts
Automatic Pallet ChangerAutomatic Pallet Changer Shop All
Lathe TurretLathe Turret Shop All
Tool ChangerTool Changer Shop All
Chip ManagementChip Management Shop All
CoolantCoolant Shop All
CounterbalanceCounterbalance Shop All
Electrical CabinetElectrical Cabinet Shop All
EnclosureEnclosure Shop All
HydraulicsHydraulics Shop All
LubricationLubrication Shop All
MaintenanceMaintenance Shop All
PendantPendant Shop All
ProbingProbing Shop All
RotaryRotary Shop All
SpindlesSpindles Shop All
TailstockTailstock Shop All
