UMC Hydraulic Vise - Installation/Removal - AD0514
Service Home How To Procedures UMC Hydraulic Vise - Installation/Removal - AD0514
Recently Updated Last updated: 02/11/2022
AD0514
This procedure will explain how to install the hydraulic vise option on the UMC series machines.
Please refer to the hydraulic workholding procedure to install the HPU, hydraulic manifold, and the other components that drive the hydraulic vise.
Pre-requisites:
  • Software version 100.20.000.1110 or higher.
Kits applied:
  • 93-1000517 HYDRAULIC VISE-6.0 FIELD INSTALL
  • 93-1000518 HYDRAULIC VISE-8.0 FIELD INSTALL
  • 93-1000519 HYDRAULIC VISE-10 FIELD INSTALL
This section is for hydraulic vises with 2 mounting bollts.
Blank platters have a no drill zone [1] of  Ø7.25 in. and ↧1.75 in. for custom workholding on these platters.
Machines sold with a blank platter also have the option of purchasing the Haas hydraulic vise.
To install the vise the user will need to drill mounting holes outside the no drill zone [1].  Home the B & C-Axis and drill using the hole pattern that follows:
  • Haas Hydraulic Vise: (2x) 1/2-13 holes at 9 in. (on center) [2]
for the mounting bolts, the mounting bolt. Use the brake bleed access hole for reference [3].
NOTE: Pictured is a UMC-500 blank platter but the no drill zone and Haas hydraulic vise hole pattern will be the same throughout all UMC models.
This section is for hydraulic vises with 4 mounting bollts.
  • 6 & 8 in. Hydraulic Vise  – 4x ½-13 at 103.6mm [2] x 63mm [3] (on center)
  • 10 in. Hydraulic Vise – 4x ½-13 at 124.7mm [2] x 63mm [3] (on center)
For the mounting bolts, the mounting bolt. Use the brake bleed access hole for reference [3].
In the position shown the air line is the hole denoted [2] use the brake bleed access port [1] as a reference.
Set the C-axis to its home position.
Clean the mating surface inside the center bore and on the spud of the hydraulic vice for chips and left over oil. Make sure the screws and washers are removed as well
To install the vise [1] carefully place the vise into the bore, make sure to align the hydraulic holes [2] inside the bore with the hydraulic holes on the vise [3]. Be sure that the O-rings [4] are in the grooves of the hydraulic holes, if they are ripped or damage, replace them immediately
NOTE: The coupler on the platter can only be installed in one orientation.  The hydraulic holes [2] can only be oriented in one way, be sure to match the holes on the coupler to those on the spud.
Use the SHCS and washer [5] to bolt the vise to the T-nuts [6] in the slot shown in the image.
 While placing the vise make sure the DOWELS [7] are in the T-slots positioned above the left T-nut and under the right T-nut. They should sit diagonally across from each other.
NOTE: Always clean inside the center bore for chips before installing the hydraulic vise.
To install the vise [1] carefully place the vise into the bore, make sure to align the hydraulic holes [2] inside the bore with the hydraulic holes on the vise. Be sure that the O-rings [3] are in the grooves of the hydraulic holes, if they are ripped or damage, replace them immediately
Use the SHCS and washer [4] to bolt the vise to the T-nuts [5] in the slot shown in the image.
 While placing the vise make sure the aligning block [6] are in the center T-slots.
To activate the vise, press [CURRENT COMMANDS] and under the workholding tab [1] select workholding type [2] to Custom Hydraulic Vise.
Adjust Clamp Force
Determine the type of Hydraulic Vise is installed on the machine.  LMC or Autogrip.
Use the Hydraulic Vise Clamp Force Chart decal to find the PSI to achive the desired clamp force.
Adjust the Hydraulic Unit pressure valve to the correct PSI.
Finally, make sure the vice actuates, to do so press the foot pedal.
Removing the Vise
To physically remove the hydraulic vise press [CURRENT COMMANDS] and disable the vise by going to the workholding tab under the device tab. Change the value of the workholding from Custom Hydraulic Vise to None.
De-pressurize the HPU  by pressing [F3] on the maintenance tab.
Remove the vise and plug the three port holes with the 5/16-18 screws provided in the kit.
Re-activate the HPU by pressing [F4] on the maintenance tab.
After the vice is removed plug the hydaulic ports with the 5-/16 screws and washers.
 NOTE: Make sure there are O-rings in the grooves before plugging with the screws.
