Lubricant, Grease, and Sealant Tables for Haas Machine Components
Service Home Lubricant, Grease, and Sealant Tables for Haas Machine Components
Jump to Section 1. Introduction 2. Spindle Lubricants 3. Spindle Gearbox 4. Spindle Gearbox 16DP-C 5. Linear Guide / Ball Screw 6. Pneumatics Lubricant 7. Side-Mount Tool Changer - Cam Box 8. Hydraulic Systems 9. Rotary - Indexer 10. Rotary - Rotary table 11. Rotary - Dual Axis 12. Rotary - HRTSS lubricants 13. Rotary - HRTSS Hydraulic Brake Fuild 14. Rotary - Tailstock 15. Machine Built - In Rotaries 16. Lathe - Turret 17. Lathe - Live Tooling 18. Lathe - Tailstocks 19. Fanuc Robot - Arm 20. WorkHolding 21. Mobil Oil - Special Properties 22. Alternative Mobil Oil - Special Properties 23. Mobil Grease - Special Properties 24. Alternative Mobil Grease - Special Properties 25. Specialty Grease 26. Sealants 27. Haas Spindle Chiller Fluid Back to Top
Recently Updated Last updated: 06/06/2025
Revision D - 6/2025
This document contains the following tables:
  1. The Lubricant tables contain the recommended lubricant type and capacity for Haas machine components.
  2. The other tables contain information about the properties of the lubricants.
  3. The Specialty Grease and Sealant tables contain the description and part numbers for each item in the table.
Go to www.haascnc.com/haas-service-parts to order replacement parts and lubricants.
If a lubricant is not available, use the Mobil Hot line.
 Note: The lubricants in this table are for all Haas machines made after 1989.
 Note: You can get the lubricants in the "Alternate Lubricant" column from automotive parts stores or large retail stores that have automotive parts.
 Note: Use the Manufacture's website, found in the "Product Page" link in the tables below, to get the latest Safety Data Sheets (SDS) or translated copies of the Safety Data Sheets.
Spindle Lubricants
MACHINE TYPE PRIMARY LUBRICANT ALTERNATE LUBRICANT CAPACITY HAAS PART NUMBER Safety Data Sheet
Mill Mobil 1, 0W-20 Mobil 1, 5W-20 128 oz (3.79 L) 93-4203 Product page | SDS [PDF]
Lathe Mobil 1, 0W-20 Mobil 1, 5W-20 128 oz (3.79 L) 93-4203
Spindle Gearbox
40-Taper (VMC) Mobil 1, 0W-20 Mobil 1, 0W-20 51 oz (1.5 L) 93-4203 Product page | SDS [PDF]
50-Taper (VMC) Mobil 1, 75W90 Mobil 1, 15W-50 34 oz (1.0 L) 93-2365 Product page | SDS [PDF]
50-Taper (HMC) Mobil 1, 75W90 Mobil 1, 15W-50 85 oz (2.5 L) 93-2365 Product page | SDS [PDF]
Lathes (with oil pump) Mobil 1, 75W90 Mobil 1, 15W-50 85 oz (2.5 L) 93-2365 Product page | SDS [PDF]
SL Gearbox Mobil 1, 75W90
Mobil 1, 0W-20
Mobil 1, 15W-50
Mobil 1, 5W-20
81 oz (2.4 L)
93-2365
93-4203
Mobil 1, 75W90: Product page | SDS [PDF]
Mobil 1, 0W-20: Product page | SDS [PDF]
ZF Gearbox Mobil 1, 75W90
Mobil 1, 15W-50
36 oz (1.1L) 93-2365 Product page | SDS [PDF]
Machine Type Primary Lubricant Alternate Lubricant Capacity Haas Part Number Safety Data Sheet
50-Taper (VMC) (With Square Sump Tank) Mobil 1, 75W90 Mobil 1, 15W-50 101 oz (3.0 L) 93-2365 Product page | SDS [PDF]
50-Taper (VMC) (With Oval Sump Tank) Mobil 1, 75W90 Mobil 1, 15W-50 85 oz (2.5 L) 93-2365 Product page | SDS [PDF]
50-Taper (HMC) (without oil pump) Mobil SHC 634 Mobil 1, 15W-50 101 oz (3.0 L) 93-9141A Product page | SDS [PDF]
Lathes (without oil pump) Mobil SHC 634 Mobil 1, 15W-50 101 oz (3.0 L) 93-9141A Product page | SDS [PDF]
Important : For Lathe tailstock linear guides, refer to the Lathe-Tailstock table on this page.
Component Primary Lubricant Alternate Lubricant Capacity Haas Part Number Safety Data Sheet
Bijur Oiler (1988-on) Mobil 1, 0W-20 Mobil 1, 5W-20 128 oz (3.79 L) 93-4203 Product page | SDS [PDF]
Pneumatic Grease-Gun Cartridge (High-Pressure)
Mobilith SHC 460
Mobil 1, Synthetic Grease 14 oz (0.41 L) 99-1686 Product page | SDS [PDF]
Reservoir Restrictor Flow and Equal Length Grease Mobilith SHC 007 If your machine still has Red Grease convert it to Haas Axis Lubrication Oil by ordering part number 93-2755A and follow the conversion procedure. N/A N/A Product page | SDS [PDF]
Haas Liquid Grease (HLG)
Note: No longer used for axis lubrication
HLG If your machine still has HLG, convert it to Haas Axis Lubrication Oil by ordering part number 93-3585 and follow the conversion procedure. N/A N/A Haas Liquid Grease: Product manual | SDS [PDF]
Haas Axis Lubrication Oil Mobil SHC GEAR 1500
SYNGEAR SH-1150 (Kluber/Summit product)
or
Klubersynth EG 4-1500
Approximately 32 oz
(58 cu-in or 0.95 L)
93-3584 (AXIS LUBE OIL REFILL 1 GALLON)
93-3585 (AXIS LUBE CONVERSION KIT HLG TO OIL)
SYNGEAR SH-1150 Product page | SDS [PDF]
Klubersynth EG 4-1500 Product page | SDS [PDF]
Mobil SHC GEAR 1500 Product page | SDS [PDF]
Toolroom Lathe Mobil Grease XHP 222 Mobil 1, Synthetic Grease 2 full strokes monthly 99-1686 Product page | SDS [PDF]
Toolroom Mill Mobil Grease XHP 222 Mobil 1, Synthetic Grease 2 full strokes monthly 99-1686 Product page | SDS [PDF]
Drill Center Axis Lubrication Mobil 1 75W-90 Mobil 1, 15W-50  100 oz (3 L) 93-2365 Product page | SDS [PDF]
COMPONENT PRIMARY LUBRICANT ALTERNATE LUBRICANT CAPACITY HAAS PART NUMBER Safety Data Sheet
Drill Center Air Regulator Lubricant Mobil DTE 24 Ultra None 8 oz (230 mL) 93-2546 Product page | SDS [PDF]
Vertical - Standard/SS Oil Gearbox ISO 220 Mobil 1, 15W-50 256 oz (7.57 L) 93-3912 Product page | SDS [PDF]
DT-1/DM-1 Oil Gearbox ISO 220 Mobil 1, 15W-50 192 oz (5.68 L) 93-3912 Product page | SDS [PDF]
Horizontal Oil Gearbox ISO 220 Mobil 1, 15W-50 288 oz (8.52 L) 93-3912 Product page | SDS [PDF]
Hydraulic Systems
EC-1600 4th Axis Brake Mobil DTE 24 Ultra
ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
117 oz (3.46 L) 93-2546 Product page | SDS [PDF]
HPU: EC-1600 platter lift cylinder Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
70 oz (2.1 L) 93-2546 Product page | SDS [PDF]
HPU: VMT-750 Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid 5 gal (19 L) 93-2546 Product page | SDS [PDF]
HPU: Lathe ST-30 and smaller Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
8 gal (30 L) 93-2546 Product page | SDS [PDF]
HPU: Lathe ST-30BB and larger Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
10 gal (38 L) 93-2546 Product page | SDS [PDF]
HRT110 Brake Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
7.6 oz (0.22 L) 93-2546 Product page | SDS [PDF]
HRT450 Brake Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
17 oz (0.50 L) 93-2546 Product page | SDS [PDF]
HRT600 Brake Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
UMC - B and C Axes Rotary Brake Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid
40 CF Counter Balance
(Height = 23.0"/ 584 mm)
64 oz (1.9 L)
(Pump strokes needed = 93)
80 CF Counter Balance
(Height = 36.0"/ 914 mm)
96 oz (2.8 L)
(Pump strokes needed = 140)
110 CF Counter Balance
(Height = 42.0"/ 1070 mm)
96 oz (2.8 L)
Rotary - Indexer
Rotary Model Primary Lubricant Alternate Lubricant Capacity Haas Part Number Safety Data Sheet
HA5C Mobil 1, 75W-90 Mobil 1, 15W-50 7 oz (0.21 L) 93-2365 Product page | SDS [PDF]
HA5C-T Mobil 1, 75W-90 Mobil 1, 15W-50 7 oz (0.21 L) 93-2365 Product page | SDS [PDF]
HA5CS Mobil 1, 75W-90 Mobil 1, 15W-50 7 oz (0.21 L) 93-2365 Product page | SDS [PDF]
HA5C(SB) Mobil 1, 75W-90 Mobil 1, 15W-50 10 oz (0.3 L) 93-2365 Product page | SDS [PDF]
T5C Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 26 oz (0.76 L)
5th: 7 oz (0.21 L)
HA5C2 Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
HA5C2-T Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
T5C2 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 26 oz (0.76 L)
5th: 14 oz (0.42 L)
HA5C3 Mobil 1, 75W-90 Mobil 1, 15W-50 21 oz (0.62L) 93-2365 Product page | SDS [PDF]
HA5C3-T Mobil 1, 75W-90 Mobil 1, 15W-50 21 oz (0.62L) 93-2365 Product page | SDS [PDF]
T5C3 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 26 oz (0.76 L)
5th: 21 oz (0.62 L)
HA5C4 Mobil 1, 75W-90 Mobil 1, 15W-50 28 oz (0.83 L) 93-2365 Product page | SDS [PDF]
HA5C4-T Mobil 1, 75W-90 Mobil 1, 15W-50 28 oz (0.83 L) 93-2365 Product page | SDS [PDF]
4th: 26 oz (0.76 L)
5th: 28 oz (0.83 L)
HA5CTS Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
HRT100 Mobil 1, 75W-90 Mobil 1, 15W-50 4 oz (0.21 L) 93-2365 Product page | SDS [PDF]
HRT110 Mobil 1, 75W-90 Mobil 1, 15W-50 1.2 oz (35 mL) 93-2365 Product page | SDS [PDF]
HRT160 Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
HRTA5 Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
HRT160SP Mobil 1, 75W-90 Mobil 1, 15W-50 14 oz (0.42 L) 93-2365 Product page | SDS [PDF]
HRC160 Mobil 1, 75W-90 Mobil 1, 15W-50 24 oz (0.71 L) 93-2365 Product page | SDS [PDF]
HRT160-2 Mobil 1, 75W-90 Mobil 1, 15W-50 28 oz (0.83 L) 93-2365 Product page | SDS [PDF]
HRT210 Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.76 L) 93-2365 Product page | SDS [PDF]
HRTA6 Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.76 L) 93-2365 Product page | SDS [PDF]
HRT210M Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.76 L) 93-2365 Product page | SDS [PDF]
HRT210SP Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.76 L) 93-2365 Product page | SDS [PDF]
HRT210HT Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.76 L) 93-2365 Product page | SDS [PDF]
HRT210HS Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.77 L) 93-2365 Product page | SDS [PDF]
HRT210SHS Mobil 1, 75W-90 Mobil 1, 15W-50 26 oz (0.77 L) 93-2365 Product page | SDS [PDF]
HRC210 Mobil 1, 75W-90 Mobil 1, 15W-50 30 oz (0.9 L) 93-2365 Product page | SDS [PDF]
HRT210-2 Mobil 1, 75W-90 Mobil 1, 15W-50 51 oz (1.51 L) 93-2365 Product page | SDS [PDF]
TH240 Mobil 1, 75W-90 Mobil 1, 15W-50 51 oz (1.51 L) 93-2365 Product page | SDS [PDF]
HRT310 Mobil 1, 75W-90 Mobil 1, 15W-50 96 oz (2.84 L) 93-2365 Product page | SDS [PDF]
HRT310SP Mobil 1, 75W-90 Mobil 1, 15W-50 96 oz (2.84 L) 93-2365 Product page | SDS [PDF]
HRT320FB Mobil 1, 75W-90 Mobil 1, 15W-50 58 oz (1.7 L) 93-2365 Product page | SDS [PDF]
HRT450 Mobil 1, 75W-90 Mobil 1, 15W-50 141 oz (4.16 L) 93-2365 Product page | SDS [PDF]
TH450 Mobil 1, 75W-90 Mobil 1, 15W-50 320 oz (9.46 L) 93-2365 Product page | SDS [PDF]
HRT630 Mobil 1, 75W-90 Mobil 1, 15W-50 422 oz (12.49 L) 93-2365 Product page | SDS [PDF]
HRT800 Mobil 1, 75W-90 Mobil 1, 15W-50 934 oz (27.63 L) 93-2365 Product page | SDS [PDF]
HRT1000 Mobil 1, 75W-90 Mobil 1, 15W-50 1536 oz (45.42 L) 93-2365 Product page | SDS [PDF]
Rotary - Dual Axis
TRT70 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 7 oz (0.21 L)
5th: 8 oz (0.24 L)
TRT100 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 12 oz (0.35 L)
5th: 6 oz (0.18 L)
TRT110 Mobil 1, 75W-90 Mobil 1, 15W-50 1.2 oz (35 mL) 93-2365 Product page | SDS [PDF]
TRT160 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 51 oz (1.51 L)
5th: 12 oz (0.34 L)
TRT210 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 77 oz (2.27 L)
5th: 26 oz (0.76 L)
TRT310 Mobil 1, 75W-90 Mobil 1, 15W-50
4th: 320 oz (9.46 L)
5th: 141 oz (4.16 L)
TR160 Mobil 1, 75W-90 Mobil 1, 15W-50
4th (Drive): 14 oz (0.42L)
4th (Driven): 28 oz (0.83 L)
5th: 26 oz (0.76 L)
TR160-2 Mobil 1, 75W-90 Mobil 1, 15W-50
4th (Drive): 14 oz (0.42 L)
5th: 41 oz (1.21 L)
TR200Y Mobil 1, 75W-90 Mobil 1, 15W-50
4th (Driven): 5 oz (0.15 L)
5th: 23 oz (0.68 L)
TR210 Mobil 1, 75W-90 Mobil 1, 15W-50
4th (Drive): 26 oz (0.76 L)
4th (Driven): 54 oz (1.59 L)
5th: 26 oz (0.76 L)
TR310 Mobil 1, 75W-90 Mobil 1, 15W-50
4th (Drive): 96 oz (2.84 L)
4th (Driven): 128 oz (3.79 L)
Warning: Do not put lubricant oil in hydraulic port and do not put hydraulic fluid in oil port. Doing so will damage the rotary.
HRT160SS Mobil 1, 0W-20 Mobil 1, 5W-20 4 oz (0.12 L) 93-4203 Product page | SDS [PDF]
HRT210SS Mobil 1, 0W-20 Mobil 1, 5W-20 5 oz (0.15 L) 93-4203 Product page | SDS [PDF]
HRT310SS Mobil 1, 0W-20 Mobil 1, 5W-20 8 oz (0.22 L) 93-4203 Product page | SDS [PDF]
HRT160SS Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid 1 oz (0.04 L) 93-2546 Product page | SDS [PDF]
HRT210SS Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid 2 oz (0.07 L) 93-2546 Product page | SDS [PDF]
HRT310SS Mobil DTE 24 Ultra ISO Grade 32, Anti Wear, Foam Resistant Hydraulic Fluid 5 oz (0.15 L) 93-2546 Product page | SDS [PDF]
Rotary - Tailstock
Tailstock Primary Lubricant Alternate Lubricant Capacity Haas Part Number Safety Data Sheet
Haas - Rotary Pneumatic Tailstock (All) Mobilgrease XHP-322 Mine (Moly) LubriMatic Moly Extreme Pressure Grease 1 full stroke every (6) months 99-1792
VR-8 / VR-11 Mobil SHC 634 Mobil 1, 15W-50 346 oz (10.2 L)
93-9141A
UMC-750 Mobil SHC 634 Mobil 1, 15W-50 346 oz (10.2 L) 93-9141A Product page | SDS [PDF]
UMC-750SS Mobil 1, 0W-20 Mobil 1, 5W-20 26 oz (0.77 L) 93-4203 Product page | SDS [PDF]
Component Primary Lubricant Alternate Lubricant Capacity Part number Safety Data Sheet
ST-10/15 Turret Gearbox Mobil DTE 24 Ultra Mobil SHC 525 128 oz (3.79 L) 93-2546 Product page | SDS [PDF]
ST-20/45 Turret Gearbox Mobilith SHC 007 Mobil 1, Synthetic Grease (Double the Capacity) 14 oz (410 mL) 93-1933A Product page | SDS [PDF]
ST Face Gear Mobilgrease XHP-322 Mine (Moly) LubriMatic Moly Extreme Pressure Grease Coat N/A Product page | SDS [PDF]
ST Turret Piston Mobilgrease XHP-322 Mine (Moly) LubriMatic Moly Extreme Pressure Grease Coat N/A Product page | SDS [PDF]
SL Face Gear Red-I, Mobil XHP-222 Mobil 1, Synthetic Grease Coat 99-1686 Product page | SDS [PDF]
SL Turret Gearbox Mobil DTE 24 Ultra Mobil SHC 525 128 oz (3.79 L) 93-2546 Product page | SDS [PDF]
Piston Seal Cover O-Ring Mobilith SHC 007 Mobil 1, Synthetic Grease Coat 93-1933A Product page | SDS [PDF]
TT-4 Gears Mobilith SHC 007 Mobil 1, Synthetic Grease Coat 93-1933A Product page | SDS [PDF]
BMT45 Mobil 1, 75W-90 No Substitute 1 Quarts 93-2365 Product page | SDS [PDF]
BMT65 & BMT75 with Live Tooling Mobilith SHC 007 No Substitute 2 Quarts 93-1933A Product page | SDS [PDF]
BMT65 & BMT75 without Live Tooling Mobilith SHC 007 No Substitute 3 Quarts 93-1933A Product page | SDS [PDF]
Live Tooling (3K) Mobil 1, 75W-90 Mobil 1, 15W-50 5.9 oz (0.17 L) 93-2365 Product page | SDS [PDF]
Live Tooling (6K) Mobil 1, 0W-20 Mobil 1, 5W-20 5.9 oz (0.17 L) 93-4203
Lathe - Tailstocks
Haas Tailstock (Grease) Mobilith SHC 460 Mobil 1, Synthetic Grease 1 full stroke every (6) months 99-1686 Product page | SDS [PDF]
Haas ACME Screw Tailstock (With mounted reservoir) Haas Haas Liquid Grease (HLG) No Substitute 16 oz (0.47 L) 93-3599 Product manual | SDS [PDF]
Haas ACME Screw Tailstock (No reservoir) Mobil SHC GEAR 1500
or
Approximately 32 oz
Note: For the ST-40/40L, do not manually apply the grease to the tailstock trucks. The machine applies the grease automatically.
Fanuc Robot - Arm
Robot Model Components Lubricant
HRP-1 (7Kg) J1 - J6 Gearbox Refer to section 7.3.2 in the Operator's manual linked in 12.1 - Maintenance Schedule in the Haas Robot Package manual.
HRP-2 (25Kg) J1 - J6 Gearbox Refer to section 7.3.2 in the Operator's manual linked in 12.1 - Maintenance Schedule in the Haas Robot Package manual.
HRP-3 (50Kg) J1 - J6 Gearbox Refer to section 7.3.2 in the Operator's manual linked in 12.1 - Maintenance Schedule in the Haas Robot Package manual.
PulseJet Lubrication
Product Type ISO VG Safety Data Sheet
White Oil Light Generic Mineral Based Oil 10 N/A
Mobil DTE 24 Ultra (Included when installed at the factory and in the feild install kit) Mineral Hydraulic Oil 32 Product page | SDS [PDF]
Mobil DTE 25 Ultra Mineral Hydraulic Oil 46 Product page | SDS [PDF]
Mobil DTE Light Mineral Circulating Oil 32 Product page | SDS [PDF]
WD 40 Penetrating Oil 3 N/A
Coolube 2210 EP Metalworking Oil 15 N/A
Tapmatic #1 Gold Tapping Oil 20 N/A
Relton Rapid Tap Tapping Oil 28 N/A
"Lard Oil"  for Aluminum and Soft Metals Cutting/Tapping Oil 40 N/A
Minimum-Quantity Lubrication
Component Primary Lubricant Alternate Lubricant Capacity Haas Part Number Safefy Data sheet
Canola Oil
Recommended for all metal applications. (Not a Mobil product)
Minimum: 5 oz (0.15L)
Maximum: 28 oz (0.83L)
93-2364 Product page
Tap Magic Eco-Oil Cutting Fluid
N/A N/A
Ecocut Mikro Plus 20
Recommended for aluminum, cast iron, and steel applications. (Not a Mobil product)
N/A N/A
Ultra Lube MQL Cutting Oil
General purpose cutting oil. (Not a Mobil product)
N/A N/A
Dropsa MK Oil 150 20 Lt
Recommended for stainless steel, low-alloy steel, brass, aluminum, and copper. (Not a Mobil product)
N/A N/A
WorkHolding
Manual/ Pneumatic Vises  Mobilgrease XHP-322 Mine (Moly) LubriMatic Moly Extreme Pressure Grease N/A N/A Product page | SDS [PDF]
Oil Description ISO Viscosity Grade Viscosity at 40°C (104°F) Viscosity at 100°C (212°F) Safety Data Sheet
SHC 625 Mobil SHC 600 series
This oil has very good performance for gears and bearings.
46 48.0 7.9 Product page | SDS [PDF]
SHC 627 Mobil SHC 600 series
100 99.1 13.9 Product page | SDS [PDF]
SHC 634 Mobil SHC 600 series
460 430.0 48.5 Product page | SDS [PDF]
Mobilgear 600 XP220 Mobilgear 600 XP series
This oil has very good performance for very high pressure and force.
220 220 26 Product page | SDS [PDF]
Mobil DTE 24 Ultra Mobil DTE 20 Ultra Series
This oil has very good resistance to oxidation properties. Use this oil in high-pressure hydraulic systems.
32 31.5 5.29 Product page | SDS [PDF]
Mobil 1, 75W-90 This engine oil is fully synthetic. It supplies very good protection from damage. It prevents worn components. N/A 95.5  14.3 Product page | SDS [PDF]
Mobil 1, 0W-20 This engine oil is fully synthetic. It supplies very good protection from damage. It prevents worn components. N/A 43.54 8.19 Product page | SDS [PDF]
Mobil 1, 5W-20 This engine oil is fully synthetic. It supplies very good protection from damage. It prevents worn components. N/A 48.3 8.8 Product page | SDS [PDF]
Mobil 1, 15W-50 This engine oil is fully synthetic. It supplies very good protection from heat. Also, it has very good resistance to oxidation properties. N/A 130.2 18.1 Product page | SDS [PDF]
Multi-Purpose Gear Oil, CRC SL24238 This is API/GL-4 SAE 140-weight non-synthetic gear oil. This oil is to be used only as an emergency substitute.
460 N/A 28.3 N/A
Kluber/Summit SYNGEAR SH-1150 This gear oil is only to be used for special cases. Contact your local Haas Factory Outlet. 1500 1513 95.8 Product page | SDS [PDF]
Grease Description National Lubricating Grease Institute (NLGI) Grade ISO Viscosity Grade Shelf Life (Years) Safety Data Sheet
Mobilith SHC 007 Mobilith SHC Series
This grease flows easily at low temperatures.
It also lets components turn with low torque.
00 460   Product page | SDS [PDF]
Mobilith SHC 460 Mobilith SHC Series
This grease supplies very good bearing protection.
1.5 460   Product page | SDS [PDF]
Mobilgrease XHP-322 Mine (Moly) Mobilgrease XHP Series
This grease has these properties:
• It does not easily become soft under very high force.
• It stays together and it stays on the components.
• It contains 5% molybdenum sulphide. This supplies more protection from wear in highly loaded plain bearing applications.
2 320   Product page | SDS [PDF]
This grease is 50% SHC 625 and 50% Mobilith SHC 007. -- 100 2 Product manual | SDS [PDF]
Mobilgrease XHP 222 This grease supplies very good bearing and gear protection. This grease has very good performance for very high pressure and force. It is resistant to coolant wash off. It is extremely tacky.
2 220   Product page | SDS [PDF]
Grease Description National Lubricating Grease Institute (NLGI) Grade ISO Viscosity Grade Safety Data Sheet
Mobil 1, Synthetic Grease This grease has these properties:
• It supplies very good protection from corrosion.
• It has very good performance for very high pressure and force.
• It supplies good protection from water contamination.
• It supplies protection in a large range of temperatures.
LubriMatic Moly Extreme Pressure Grease This grease has these properties:
• It contains lithium and molybdenum disulfide. This lets components move smoothly across other components.
• It supplies good bearing and gear protection. It has good performance for very high pressure and force.
1.5 460
Product page (PN: 11335) | SDS [PDF]
Specialty Grease
Grease Name Description Haas Part Number Safety Data Sheet
Mobil Grease XHP 222 This helps the way covers move more easily across the casting. 99-1686 Product page | SDS [PDF]
Electrical Grease This protects the electrical connectors from coolant. 99-1793
Sealants
Sealant Name Description Haas Part Number Safety Data Sheet
Sikaflex, 1A White This seals sheet metal panels together. 99-4460A Product page | SDS (on product page)
Sikaflex, 1A Gray This seals the space between the panels. 99-0121 Product page | SDS (on product page)
RTV 108 Apply this to make a gasket. 99-4465 Product page | SDS [PDF]
Volara 4A This is used as a sealant for the Y and X axes way covers. N/A N/A
RTV ASI 335 This is used as a sealant for the Y and X axes way covers. Apply this to the linear scale machines. 99-4452
Important: Information on refilling spindle Chiller fluid can be found in the H-5AX Singe Yoke Spindle Head Troubleshooting guide. This information will apply to the Double Yoke Spindle Head as well.
 Note: For more information about Spindle Chillers use the Haas Spindle Chiller - Operator's/Service Manual.
VR/GM Spindle Chiller ASSY 5AX DOWFROST HD INHIBITED PROPYLENE GLYCOL  (Not Sold by Haas) None 5 gallons (18.93L) N/A Product page | SDS [PDF]
DC Spindle Chiller (for GM/VR machines only) Mobil Velocite #3 Oil None 8 Liters 93-4894 Product page | SDS [PDF]
HDC Spindle Chiller Mobil Velocite #3 Oil None Approximately 25 Liters 93-4894 Product page | SDS [PDF]
DC Spindle Chiller DOWFROST HD INHIBITED PROPYLENE GLYCOL  (Not Sold by Haas) None 8 Liters N/A Product page | SDS [PDF]
