Auto Air Gun (AAG) - Troubleshooting Guide
Service Home Auto Air Gun (AAG) - Troubleshooting Guide
Recently Updated Last updated: 02/17/2020
Jump to Section 1. Introduction 2. Symptom Table 3. Electrical Diagram Back to Top
The Auto Air Gun (AAG) supplies high-pressure / high-flow air through an adjustable cylinder and retractable barrel that you aim directly at the tool’s cutting edge. AAG provides a constant air blast to the cutting tool to clear chips safely and automatically during dry machining, or to blow chips and coolant out of deep pockets. An M83 code starts the AAG. An M84 code stops the AAG.
The AAG does not operate. The air line to the AAG is kinked or broken. Make sure the airline going to the AAG is not kinked or broken.
The AAG solenoid is not operating correctly. Disconnect the airline going to the AAG, command an M83, check that enough air comes out of the solenoid. If not refer to the Solenoid - Troubleshooting Guide.
No voltage going to AAG solenoid. Command an M83 then put a voltage tester to the wires of the AAG solenoid. If no voltage detected then test the I/O PCB. Refer to the above electrical diagram.
Electrical Diagram
