      • Fiber Laser
      • VF-4SS
15 - Mist Condenser
Chip Removal and Coolant - Service Manual
  • 1 - Chip and Coolant - Introduction
  • 2 - Auxiliary Coolant Filter
  • 3 - Standard Flood Coolant
  • 4 - Oil Skimmer
  • 5 - Programmable Coolant
  • 6 - Chip Auger
  • 7 - Coolant Chiller
  • 8 - Chip Conveyor - UMC
  • 9 - Chip Conveyor - Lathe
  • 10 - Coolant Refill
  • 11 - High Pressure Flood Coolant
  • 12 - Through-Spindle Coolant
  • 13 - Through-Tool Air Blast
  • 14 - Haas Chip Lift
  • 15 - Mist Condenser
  • 16 - Coolant Level Float Sensor
  • 17 - Mini Conveyor
  • 18 - Coolant VFD
  • 19 - Coolant Sanitizer
  • 20 - Chip Separator
  • 21 - Chip Tray Strainer
  • 15.1 Mist Condenser - Install
  • 15.2 Mist Condenser - Troubleshooting
Mist Condenser - Installation
AD0453
This procedure will show you how to install the Mist Condenser option on VF's, DT/DM's, and Lathes.
Note: Lathes must have been built after 4/1/2021 for this option.
Machine requirements:
  • Software Version 100.19.000.1120 or higher.
  • An I/O hinge door is needed, order 93-1000573 I/O DOOR ASSY HINGED only if the hinge door is not included in the kit.
    Use the following kits on VF's with VFD's and other mills and lathes:
  • 93-1000648 MIST CONDENSER KIT VF SML/MED W/TMD
  • 93-1000351 COOLANT MAINTENANCE PACKAGE MIST COLL
  • 93-1000649 MIST CONDENSER KIT VF-LRG TMD
  • 93-1000506 COOLANT MAINTENANCE PKG MIST COND VF LRG
  • 93-1000505 MIST CONDENSER FIELD INSTALL DM/DT
  • 93-1000507 COOLANT MAINTENANCE PKG MIST COND DT/DM
  • 93-1000636 MIST CONDENSER SYSTEM LATHE
    Note: Use this kit for UMC-350 machines
  • 93-1000637 COOLANT MAINTENANCE PKG MIST COND LATHE
    Use the following kits for VF's without a VFD:
  • 93-1000018 MIST CONDENSER KIT VF SML/MED W/O TMD
  • 93-1000385 MIST CONDENSER KIT VF-LRG W/O TMD
Mist Condenser Cutout Dimensions
Some machines do not have the necessary cutout. For these machines, use these templates:
DC-1 Mist Condenser Cutout:
On the top of the machine enclosure, measure the dimensions [A] from the front of the machine and [B] from the right side of the machine. Mark the center [C]:
  • A - 9.50" (241.3 mm).
  • B - 9.50" (241.3 mm).
Measure the dimensions [D], [E], and [F]:
  • D - Ø6.50" (165.1 mm).
  • E - Ø9.843" (250.0 mm).
  • F - 4X Ø0.356" (9.0 mm).
Cut the (1) large hole [D] and the (4) small holes [F].
DC-2 Mist Condenser Cutout:
On the top of the machine enclosure, measure the dimensions [A] from the front of the top panel and [B] from the left side of the top roof panel. Mark the center [C]:
  • A - 14.4" (365.76 mm).
  • B - 12.2" (309.88 mm).
Register Box Cutout Dimensions
DC-1 Register Box Cutout:
On the top of the machine enclosure, measure the dimension [B] from the back of the top left panel and [A] from the left side of the top roof panel. Mark the center [D]:
  • A - 4.59" (116.58 mm)
  • B - 14.37" (365 mm)
Measure the dimension [C]:
  • C - Ø3.25" (82.55 mm)
Cut the hole [C] from the center [D].
Measure the dimension [E] from the back of the top left panel and from [H] the left side of the top roof panel. Mark the center.
  • E - 5.37" (136.39 mm)
  • H - 3.34" (84.83 mm)
From the mark that was made, measure [G] and [F].  Place a mark for each dimension. Repeat this process to mark the fourth hole.
  • G - 2.5" (63.5 mm)
  • F - 18.0" (457.2 mm)
Measure the dimension [I] for each of the four clearance holes.
  • I - 4X Ø0.206" (5.23 mm)
Cut the holes [I] from the center of each mark.
DC-2 Register Box Cutout:
  • A - 11.21" (284.73 mm)
  • B - 14.40" (365.76 mm)
  • E - 5.40" (137.16 mm)
  • H - 9.96" (252.98 mm)
  • I - 4X Ø0.21" (5.33 mm)
Electrical Installation - TMD connection
Note: This section applies to the following service kits:
  • 93-1000648
  • 93-1000351
  • 93-1000649
  • 93-1000506
  • 93-1000505
  • 93-1000507
  • 93-1000636
  • 93-1000637.
Install the TMD card onto the hinge door located as shown in the picture using the spacers [1] and the hardware [2].
  • If the machine has hinge door PN 25-0512D use (2x) 1/4-20 SHCS to attach the TMD card
  • If the machine has hinge door PN 25-0512E use (2x) 10-32 SHCS and (2x) washers to attach the TMD card
if you do not have the hinged door installed please refer to the I/O PCB Hinged Door Installation procedure.
The mist condenser will be powered from the TMD card, the mist condenser will connect to P1 on the TMD card. The TMD card will connect to the I/O board via P69. The TMD card will be powered from the transformer and will connect to P4 on the TMD card.
NOTE: Make sure that TMD card has a jumper installed on P3 in between pin 1 and 2 (the bottom two pins).
Electrical Installation - VF's without Variable Frequency Drives (VFD)
  • 93-1000018
  • 93-1000385
NOTE:Perform the steps in this section for machines that do not have a variable frequency drives [1] installed above the power card.
Turn off the control cabinet.  Open the control cabinet door if your machine has a variable frequency drive to go to the next section.
Turn Off the main circuit breaker [1].
Remove the cover from the PSUP PCB [2].
Remove the cover from the Mist Condenser PCB [3].
Mount the Mist Condenser PCB above the PSUP PCB.
Install the ground decal [4] next to the ground lug.
NOTE:
Make sure the ground decal is visible and that the green arrow points towards ground lug.
Remove the cover from the cable channel.
Disconnect the cable from the PSUP PCB at P11. Pull the cable slack from the cable channel and connect it to the Mist Condenser PCB at P1.
Connect cable P/N 33-0538 to the Mist Condenser PCB at P1A. Connect the other end to the PSUP PCB at P11.
Connect cable P/N 33-0536 to the mist condenser PCB at P3. Connect the other end to the I/O PCB at P69.
Mist Condenser Unit - Installation
VF-1 to VF-5 pictured
Remove the cover plate [1] from the top of the machine enclosure.
Make sure the mist condenser unit has the two gaskets [2] and (4x) vibration isolators [3] installed.
Place the mist extraction unit so the outlet port [4] is facing the spindle.
Secure it from the underside of the panel with washers and flange nuts [5] provided in the kit.
Note: Machines with an umbrella toolchanger or a 70 pocket SMTC may need to rework the top left roof panel.
VF-6 pictured
ST Standard Bed pictured
Make sure the mist condenser unit has (2x) gaskets [2] and (4x) vibration isolators [3] installed.
Place the mist extraction unit so the outlet port [4] is facing the BACK of the machine.
DM/DT with Auto Window Option
Make sure the mist condenser unit has the (2x) gaskets [2] and (4x) vibration isolators [3] installed.
Place the mist extraction unit so the outlet port [4] is facing the front on the machine.
Secure it from the underside of the panel with washers [5] and flange nuts [6] provided in the kit.
DC-1 pictured
Remove the knock out [1] from the top of the machine enclosure.
DC-2 pictured
Place the mist extraction unit so the outlet port [4] is facing the front of the machine.
Locate the Mist Condenser motor fan cable [1] cut the zip ties and feed the cable [1] through the motor housing grommet [2].
Coil the excess cable [3] and secure it with zip ties and cable clamp.
Connect the Mist Condenser power cable to the extension cable P/N 33-9537.
DC-1 Cable Routing:
Route the motor cable as shown.
Be sure the cable goes through the cutout and into the control cabinet.
Use magnetic cable holders to hold the cable to the sides of the top of the enclosure.
DC-2 Cable Routing:
Mist Condenser Register Box - Installation
VF, DT/DM, DC-1/2 Register Box Installation
On the left side of the machine, open the window to remove the register box roof panel.
The register box [1] is install from inside the machine, use the four fastener to secure the register box to the top of the roof.
Loosen the hose clamp [2] and install the hose elbow [3].  Leave the hose clamp loose for now.
NOTE: Make sure the high flow vent points as shown [4].
ST Line Register Box Installation
Above the spindle of the machine, remove the register box roof panel.
The register box [1] is installed from inside the machine, use the four fasteners [2] to secure the register box to the roof of the machine.
Loosen the hose clamp and install the hose elbow [3]. Leave the hose clamp loose for now.
Note: If PN: 25-14616A MIST CONDENSER REGISTER BOX LATHE interferes with the Z-Axis Waycover. Install PN: 25-14616B.
NOTE: The hose elbow and the high flow vent [4] will be facing towards the Mist Condenser unit.
Mist Condenser - Hose Routing
DT/DM Hose Routing
Route the hose [1] from the mist condenser along the FRONT of the machine to the register box on the other side.
The register bayonet lock should be facing the front of the machine [2]. Insert the hose into the bayonet lock and rotate the hose to lock it into place.
Insert the other end of the hose to the mist condenser port.
Secure the hose at each end using the magnetic hose clamps and add both mist condenser hose brackets around wiring to secure it from falling from the enclosure.
VF-1 to VF-5 Hose Routing
Route the hose [1] from the mist condenser along the front of the machine to the register box on the other side.
Rotate the elbow [2] to the desired position and secure the hose clamp [3].
Insert the hose into the bayonet lock and rotate the hose [4] to lock it into place.
Insert the other end of the hose to the mist condenser port [5].
Secure the hose at each end using the magnetic hose clamps [6].
VF-6 to 9 Hose Routing
Route the hose from the mist condenser along the front of the machine to the register box on the other side.
VF-10/11 Hose Routing
VF-12 Hose Routing
ST Standard Bed Hose Routing
Route the hose from the mist condenser along the TOP of the machine to the register box in in the middle.
Insert the hose into the bayonet lock and rotate the hose to lock it into place, then secure the hose clamp.
Secure the hose at each end using the magnetic hose clamps.
DC-1 Hose Routing
Route the hose from the mist condenser along the top of the machine to the register box on the other side.
DC-2 Hose Routing
Secure the hose at each end on the top roof panel using the magnetic hose clamps.
Verification
Reinstall all the covers, turn on all the circuit breakers.
Press [Power On].
Install necessary patches.
In [MDI] run the following program:
M158;
G04 P20.;
M159;
 The mist condenser fan should run for 20 seconds then turn Off.
 NOTE:  There is approximately 10 seconds delay after the MDI program completes, after this the mist condenser will turn OFF.  If you like to turn on the mist condenser without this shut off delay, go to the CURRENT COMMANDS>DEVICES>MECHANISMS>MIST CONDENSER and press [F2] to turn it on.
Mist Condenser - Troubleshooting Guide
The Haas Coolant Mist Condenser is a complete closed-loop recirculation system that extracts coolant mist from the machine’s enclosure, runs it through dual mesh filters to condense the coolant, and then returns the condensed coolant and clear air to the enclosure.
SYMPTOM POSSIBLE CAUSE CORRECTIVE ACTION
Loud motor / excessive vibration Damaged motor / imporperly installed rubber bushings Refer to Motor section below
Motor not turning on Wiring  Refer to Electrical Diagram section below
Poor recirculation Clogged mesh filters / incorrect motor phasing
Clean and re-intall filters and verify the phasing on the motor
Refer to Air flow direction section below
Air Flow Diagram
Note : When verifying phasing ensure that the air follow this path or the phasing would need to be switched.
The coolant mist is extracted by the mist condenser through dual mesh filters then returned back into the work envelope through the register back.
Letter Box Fitment Issue (Lathe)
Electrical Diagrams
This diagram only applies to VF machines without Variable Frequency Drives (VFD)
This diagram applies to machines with a TMD card.
The mist condenser is powered by the TMD card, the mist condenser will connect to P1 on the TMD card. The TMD card will connect to the I/O board via P69. The TMD card will be powered from the transformer and will connect to P4 on the TMD card.
Note : Make sure that TMD card has a jumper installed on P3 in between pin 1 and 2 (the bottom two pins).
Motor
Verify that the rubber bushings [1] are properly seated and are not damaged.
Note : Damaged bushings will lead to excessive vibrations to be transmitted to the machine which may sound like a failing motor.
Verify that the ground wire [5] is fully tightened and properly seated.
Ensure that wires are fully seated into the lever nut connectors [4] and [3].
