SHRINK FIT HOLDERS
HAAS TESTED. HAAS PROVEN.
  2. Mill Toolholding
  3. Shrink Fit Holders
SHRINK FIT TOOLHOLDERS OVERVIEW
Shrink Fit Toolholders
Shrink fit toolholders rely on the thermal expansion characteristics of metal to provide extremely accurate toolholding, with very high grip force. The bore of the shrink fit toolholder is engineered to be slightly smaller than the diameter of the cutting tool. When the toolholder is heated, the bore expands, allowing the cutting tool to drop in. When the toolholder cools, the bore contracts, firmly clamping the cutting tool in place.
A special shrink fit machine is used to properly heat and cool the toolholders quickly, reducing the time needed to change cutting tools, and ensuring that toolholders are not overheated.
  Benefits:
  • Very low runout (< 0.0001" TIR)
  • Very accurate
  • Very high grip force
  • Small nose diameters for better access
  • Quick tool changeovers
  • Low maintenance
    Applications:
  • High-volume production
  • High-accuracy machining
  • High spindle speeds and feedrates
  • Long-reach applications
Toolholder and Pull Stud specifications
Toolholder Maintenance
Recommended for carbide cutting tools only.
System of Measurement( 0 )
Taper( 0 )
[ØD] Bore Diameter( 0 )
[GL] Gage Length( 0 )
Maximize the performance of your milling operations with our high-precision shrink fit tool holders. Explore a selection of HSK, CAT, and BT tool holders designed for efficient and precise toolholding. Our shrink fit holders offer superior rigidity, vibration damping, and runout accuracy for optimal machining performance. Choose the right tool holder size and configuration for your specific applications and elevate your milling processes to achieve exceptional results.
0 items
Sorry, those parameters return no results..
Try removing a filter and searching again.
