  2. Measuring & Inspection
  3. Bore Gauges
Bore Gauges Overview
Haas dial bore gauges are designed to measure holes with close tolerances and can even measure hole roundness and hole taper, which can easily affect the hole diameter. Watch as John walks through the lineup of dial bore gauges available in inch and metric.
Bore Gauges Details
Haas Tooling offers a complete range of bore measuring tools, with a variety of digital, mechanical, and dial designs. With three unique styles, each offers its own method and special features for accurately and precisely measuring bores.
Balanced: Negative values on one side of zero, and positive values on the other
Continuous: The value keeps ascending until the dial returns to zero
  • Inch (U.S. only) and metric versions available
  • Wide selection of ranges for large and small parts
  • Large dial or digital display for easy reading
  • Carbide, ceramic, and stainless-steel contact points for durability
Snap Bore Gauges - Digital Only
________________________
Haas Snap Bore Gauges are designed for accurately measuring the bore diameter of parts and features. All Haas snap bore gauges have three contact points for better accuracy and precision when measuring round holes. The anvils are made of carbide to ensure a long service life.
  • Carbide measuring tips
  • Dual-dimensioned calibration ring
  • 330° Display rotation
  • Resolution: 0.00005 in \ 0.001 mm
  • Tolerance setting for quick GO/NO-GO checking
  • Economic grip and handle for quick engagement and disengagement of contact points.
  • Battery Type: CR2450
  • IP rated for dust and liquid resistance
Filter For Snap Bore Gauges Micrometers
3-Point Bore Micrometers - Standard Only
3-Point bore Micrometers are designed to measure inside-hole diameters. 3 points extend to make contact with the inside diameters of a hole and provide an accurate reading. Haas 3-point bore Micrometers include setting rings and extension rods for reaching deeper holes.
  • Carbide anvils for wear resistance and long service life
  • Ratchet stop thimble
  • Includes Setting Rings for zero-point adjustment
  • Hardened, ground, and lapped spindle for ultimate accuracy
  • Available with extension rods
  • Made in accordance with DIN 863 standard
  • Graduations available in 0.005 mm, 0.001 mm, 0.0002 in,
    and 0.0001 in
Filter For 3 Point Micrometers
Dial Bore Gauges
Dial Bore Gauges are available in a wide variety of lengths and ranges. These gauges feature carbide anvil tips for long service life.
  • Inch graduations (U.S. only): 0.0005" standard, 0.0001" high resolution
  • Metric graduations: 0.01mm standard, 0.001mm high resolution
  • Measure IDs from 0.4" (10mm) up to 2.4" (60mm) with standards sets, and up to 6" (160mm) using the extensions supplied with the full kit
  • Depth reach of up to 6" \ 150mm
  • Carbide & ceramic anvils available
  • Both balanced and continuous dial numbering options are available
Filter For High Resolution Dial Bore Gauges
Filter For Standard Dial Bore Gauges
BORE GAUGE VIDEOS
Dial Bore Gauges & Sets
