HEIGHT SETTERS Overview
Accurately Set Tool Length Offsets
Manually setting tool length offsets can be very time consuming, and leaves room for error if done incorrectly. Height setters play a crucial role in optimizing machining operations by streamlining tool setup process, enhancing machining accuracy, and improving overall productivity. The Haas Digital Height Setters are available in 50mm (1.9685") and 100mm (3.9370") configurations, and easily switch from inch to metric measurements.
  • 3-point magnetic base
  • IP65 rated for dust and liquid resistance
  • Stainless steel contact surface
  • Instant switching between inch and metric
  • Gauge pin included for quick zero-point calibration
  • Lightweight aluminum housing
  2. Measuring & Inspection
  3. Height Setters
